Bubble window blues...
Discussion in 'A-Frame PopUps' started by A-Ranger12, Apr 6, 2020.
  1. A-Ranger12
    A-Ranger12 Active Member
    189
    110
    Feb 25, 2020
    Western NY
    This is more to vent than anything. I love the bubble windows on our Aliner. That's what drew us to it in the first place. Having those giant windows sure does open up the space. It also gives me just enough headroom to sit comfortably at the dinette or reclined on the sofa.
    But, wow, those are attached with hopes and dreams! One window has 3 of the 4 corners lifting up after stripping out the old caulk. Both windows had evidence of failed seals on the "up" side when the roof is raised. It doesn't help that water can pool there during storage, especially the rear window. Glad the roof and walls are a composite foam and fiberglass, so rot isn't as big a worry.
    The plan in progress right now is to strip the old caulk, let any residual water dry, use 3M Extreme Bond double sided tape to stick the lifting corners back down, apply painter's tape to the areas I don't want new caulk (Sika Sikasil N Plus silicone sealant, to be precise), and apply new caulk around the windows. That should stop the leaks. Yes, it's a lot of labor. Yes, I could have fired the money cannon at it with Eternabond tape and been way ahead on time. I want it to look as factory as possible. And learn something in the process.
    Feel free to commiserate, laugh, or nitpick my plan!
  2. Sjm9911
    6,950
    4,337
    Not knlwing anything about a lines, but i thought windows were put in with butyl tape. Then you can seal with dicore non sag of you want to. Silicon is frowned upon. Ask around here , im sure others have replaced there seels already. Better to take someones proven solution then to try and wing it on your own.
  3. A-Ranger12
    189
    110
    Feb 25, 2020
    Western NY
    I did.
    I was told to stay away from Dicor, and recommended this one by name. This specific sealant is used for fiberglass and polycarbonate, and lists RV's as a use. It's not box-store silicone caulk.
  4. Sjm9911
    6,950
    4,337
    Looks ok for a sealent, says its super flexable. You are sealimg around thw window, but how does the tape hold up? Are you removing the whole window and reinstalling it? Or just trying to get it to seal where it came up?
  5. Strawhouse
    Strawhouse Well-Known Member
    1,600
    610
    Oct 4, 2015
    Muskoka, Ontario
    If you have to turn to Eternabond as a last resort, I have a friend that used it on her front bubble window. True, it doesn't look factory, but it looks okay and solved the leaking problem.
  6. A-Ranger12
    189
    110
    Feb 25, 2020
    Western NY
    The latter, using it to stick down raised up parts. I've used this tape to hold on exterior car trim with broken tabs. A little piece held on for years adhering ABS plastic to painted steel. It should work fine holding on plastic windows to fiberglass.
    I'm also working the sealant under the raised sections to help the tape.
    One window was completed last night. Looks factory.
  7. Sjm9911
    6,950
    4,337
    Ok nice. Good luck with the fix.
  8. Brent Engel
    Brent Engel New Member
    Apr 5, 2020
    Would you post a pic when you’re done? Curious to how it looks with the black eternabond.
  9. A-Ranger12
    189
    110
    Feb 25, 2020
    Western NY
    I'm not using Eternabond. The tape I'm using is under the window corners, sticking down corners that raised up when the old sealant got cut away. The new sealant looks like the factory stuff, with the goal of having the repair look factory.
    I'll post pictures once I figure out how.
    Brent Engel likes this.
  10. Carolelynn74
    Carolelynn74 New Member
    Nov 20, 2018
  11. Enigmacamper
    Enigmacamper Active Member
    183
    25
    Nov 5, 2017
    We had a slight leak in our front window and went straight for the eternabond as we were on a trip and had a lot of rain expected. I LOVE ETERNABOND. I had no idea before that there was such a fantastic product, lol.
    Does it look perfectly factory, not entirely, but it looks nice and that stuff is major. Seriously love it. I will probably Eternabond any weak looking spots immediately upon our next camper purchase, if we do ever move on.
  12. Econ
    Econ Well-Known Member
    687
    333
    Aug 18, 2019
    Deep South
  13. A-Ranger12
    189
    110
    Feb 25, 2020
    Western NY
    Enigmacamper likes this.
  14. A-Ranger12
    189
    110
    Feb 25, 2020
    Western NY
    Update: no leaks from the windows after a day of rain!
