Busted axle - suggestions?
Discussion in 'Tires / Brakes / Bearings / Axles' started by mountainbikeguy, Dec 9, 2014.
  1. mountainbikeguy
    mountainbikeguy New Member
    59
    Oct 24, 2013
    Coming home from a 600 mile trip, the dexter torsion axle on my 1990 Starcraft Starflyer tore away from the steel frame which caused the tire on one side to go into the wheel well and blowout. I thought it was just a flat at first, but when I looked at the damage, I saw the steel lip ripped from the frame. I had it towed to a local trailer company, but they wanted $1100 to fix it which includes a new axle. I only paid $1800 for the whole trailer so I decided to park it for awhile.
    Should I take this opportunity to go to a leaf spring suspension since I mainly boondock with it? Any cheaper solutions?
  2. R00
    R00 Active Member
    1,286
    17
    Aug 10, 2014
    Leaf springs on independent axles (i.e. no thru axle)
  3. R00
    R00 Active Member
    1,286
    17
    Aug 10, 2014
    Ouch I didnt catch the frame damage. That trailer is hurtin' fer certain. :-(
  4. 94-D2
    94-D2 Happy Campin'
    2,281
    139
    May 21, 2010
    Sutter Creek CA
    You can always find a 3500 lbs doner. A swap is as complicated as finding the fulcrum, marking the appropriate spring mount locations, a couple welds, some bolt up eyelets and shackles and the necessary cans or bottles of your favorite malted beverage. A few buds to help and it's almost as much fun as the camping.
    That would be my suggestion.
  5. mountainbikeguy
    59
    Oct 24, 2013
    I have no idea why the first photo is upside down. It's right side up on photo bucket.
  6. mountainbikeguy
    59
    Oct 24, 2013
    Yeah it looks pretty bad. The damage is only on the axle mounts which are welded on to the frame. The frame itself is fine.
  7. Wayne In Florida
    Wayne In Florida Member
    301
    Jul 5, 2013
  8. tenttrailer
    3,437
    467
    Jul 18, 2013
    Thornville, OH
    since the axle is bolted onto the frame and it looks like it broke where there is a tab. Could you remove the section on the frame and have it welded back together using 1/4 inch thick plate to span the two sections. If so I would also have plates added to the other side.
    If you can do this. Wrap the axle section of the tube with wet rages to keep it cool because there is rubber in the axle and you would not want it to melt.
  9. tsimpler
    tsimpler New Member
    37
    Mar 13, 2014
    Duct tape, shoe goo, and some bailing wire and she'll be all gooder.
    Ok maybe a welding shop is the answer.
    Trent
  10. mountainbikeguy
    59
    Oct 24, 2013
    That sounds good. I'm not a welder but maybe I can find a buddy who could do it.
  11. BigBaron
    4,583
    Jun 21, 2012
    Serious rust I see. The force is gone with this one.
    New axle you must. LOL
  12. dcbain
    dcbain New Member
    342
    Apr 28, 2014
    I'd weld that, plating as necessary. To be fair, my son is a skilled welder so I'd do any fabrication; he'd then do the welding while I stand and criticise! The heat should be far enough from the rubber inserts to not affect them. I'd certainly scratch my head for a long time before I spent the price of a new axle.
  13. mountainbikeguy
    59
    Oct 24, 2013
    I believe what looks like rust is red dirt from a recent trip to Arizona.
  14. tenttrailer
    3,437
    467
    Jul 18, 2013
    Thornville, OH
    I would make sure they are a real welder?? Not someone that just hack. I can weld but I would not do it myself. This is a suspension part. I think it will need to be ark welding and make sure they wrap the square tube with a wet cloth and keep it wet. I would think if you take the axle into a shop it would be about $100?? also have them look at the other side??
    A true welding shop may figure out a better way?
  15. xshield
    xshield New Member
    508
    Feb 11, 2011
    I'd weld that - both side I'd reinforce. Any skilled welder using correct rods and plates will make it stronger than when you bought it.
  16. turborich
    turborich Active Member
    1,908
    Jun 22, 2010
    Las Vegas, NV.
    There is absolutely nothing wrong with torsion axles. I have had leaf springs snap in half on a conventional "sprung axle" I once replaced a torsion axle with a leaf spring set up and was very disappointed with how it towed afterwards however it all depends on the trailer. They both have strong points. Just wanted to make this point. The same as the radial vs. bias tire argument. They both have strong points on different applications.
    As far as your axle goes, it it's still true then I would just weld it back up and reinforce it as was suggested by xshield. What he says is absolutely correct and will save you money. While you're at it I would also reinforce the other side.
  17. zorak
    zorak Member
    202
    Apr 7, 2012
    Actually i would weld that with a mig or fluxcore wire fed welder. We do stuff like this all the time. I agree that some reinforcement would definetly be in order as well. I would keep a running hose nearby, weld a little, and put water on the axle and the weld area to col it off, then repeat til done. I would use a decent welder though. I wouldn't trust one of those $99 ones from harbour freight. For the price of a new axle you could buy a decent enough welder, a roll of wire and a cheap hood and fix it yourself, plus you will have a welder and a new skill in your toolkit.
  18. lifespeed
    lifespeed Member
    693
    Aug 26, 2014
    The torsion axle must be replaced. They do have a limited lifespan (torsion rubber breaks down, eliminating suspension travel and causing the subsequent failure) which was obviously exceeded. Yes, the torsion axles tow nicer than leaf springs.
    I paid $660 for a new axle on my '94 StarCraft (no brakes) including installation. The axles bolt in, no welding should be required.
    Just to be completely clear, there is no "fixing" of this problem with welder, wet rags, buddy Billy-Bob and cans of beer. A new axle must be ordered and replaced.
  19. dcbain
    dcbain New Member
    342
    Apr 28, 2014
    Lifespeed raises a good point. Has the damage been caused by a failure of the torsion rubbers? The break is through the axle retaining bolt holes; does that suggest a stiffening of the suspension action? Unfortunately I can't see a way of testing the existing suspension movement without remounting it to the trailer; some welding to make good the fixings will be needed to either fit new or replace the old one. So many questions . . .
  20. zorak
    zorak Member
    202
    Apr 7, 2012
    I see. I guess i know better than to give any advice anymore. I am not a " bubba" ,jackleg or whatever else you think! I am however a welder for the past 30 years and I have built trailers from scratch! I will from now on keep my opinions and ideas to myself. Have a nice day!
