Buying a New Awning. Got a Question!!
Discussion in 'General Camping Discussion Forum' started by kmeece, May 17, 2013.
  1. kmeece
    kmeece New Member
    136
    Apr 19, 2013
    I found an awning online at a good price due to the fact that the color is discontinued. The awning states that it is 8 ft. So, when I went to measure the old awning bag, it was 9 ft. Do you think it would be a big deal to install a shorter one?
    Need some insight...
  2. kitphantom
    12,266
    1,261
    It work fine on the c-channels on our pup. the awning just slides into the channel and is (usually) secured in place by screws or the like. So, if it is shorter than the original, you'd just place it where you wanted (centered or not) and fasten it. [For a couple of reasons, we did not actually attache it, we slide it in as we set up camp, and it is sometimes left home.) I'd think shorter would be better than longer.
  3. adirondackcamper
    adirondackcamper Member
    193
    Jan 14, 2013
    I would double check on the size. What I was told by an RV dealer is that they come in 7ft, 9 ft and 11ft, intended for PUPS 8ft, 10ft and 12ft. So my guess is that it may actually be only 7ft wide intended for an 8ft camper. Still it should work if you're willing to go smaller.
  4. sssrip
    sssrip New Member
    May 16, 2013
    Are there more or is this the only one? Is so do you mind sharing the source?
  5. kmeece
    kmeece New Member
    136
    Apr 19, 2013
  6. sssrip
    sssrip New Member
    May 16, 2013
    If you have not purchased yet go thru this link and use the code JCWMEM to save 10% on your order.
    http://www.dpbolvw.net/click-7060218-11333137">
    <img src="http://www.tqlkg.com/image-7060218-11333137" width="300" height="250" alt="" border="0"
  7. N7VDR
    N7VDR New Member
    Jan 28, 2012
    I have tried all those promo codes and none of them work. Says item in cart does not qualify for the discount. Thats sux cuz I'd be all over one of these with a 10 percent discount. I will probably buy one anyway.
  8. kmeece
    kmeece New Member
    136
    Apr 19, 2013
    I tried them all too... no luck. This one was the best deal I could find. Hope it works out... yet, anything will be better than our old one. Thanks for link anyway!
