Cabling system
Discussion in 'General Camping Discussion Forum' started by Chad Beck, Mar 4, 2020.
  1. Chad Beck
    Chad Beck New Member
    Feb 14, 2020
    I have recently bought a 2004 Fleetwood Utah. The manual crank system works good cranking upo but this past weekend I was putting it down for the week and while cranking it down it was very hard to crank. Almost like it was in a bind. It was harder to crank down than it was to crank up. Any suggestions or ideas would be very welcomed!!!
  2. McFlyfi
    McFlyfi Active Member
    524
    246
    Aug 1, 2014
    Thousand Oaks CA
    Make sure the cables haven't jumped off the pulleys. Pull the whiffletree cover and make sure there isn't any debris inside. Clean & re-grease as necessary.
  3. bobinfleet
    bobinfleet Well-Known Member
    825
    332
    Sep 2, 2011
    Hampshire UK
    As McFLYfi said check the cable run for stiff/worn pulleys, cables binding/catching up
  4. jmkay1
    5,488
    2,275
    First of all welcome from Northern Virginia and a fellow Fleetwood Utah owner.
    As previously mentioned crawl under the camper and open the wiffletree cover. Verify that the screw like thing is cleaned and not gunked up. Spread some lube on the screw to ensure easy moving. Follow the cables to each corner and make sure the cables are still on the pulleys. Then spray a drylube on the pulleys to ensure they are moving freely.
    If you have a chance check out "the Coleman guy" on YouTube there are a lot of helpful videos he posted.
    Chad Beck likes this.
  5. silvermickey2002
    4,760
    534
    Sep 11, 2008
    Morris County, NJ
    As others have said check the cable routes to make sure cable is on pulleys and make sure pulleys are turning with the cable. Check the whiffletree and clean/regrease as needed. Also spray some silicon on the pulley bearings (Not the cable). Clean the cranking assembly!! This happened to me, cranked up fine, but cranking it down was hard and seemed like it was binding. I watched the Coleman guy videos and they were very helpful when it came to cleaning the crank assembly!!!
    Another thing, on Coleman/Fleetwood campers the stabilizers MUST not be touching the ground when cranking up or down. This is to prevent binding. Coleman/Fleetwood state that the frame does flex when cranking up or down. By having the stabilizers down on the ground it does not allow the frame to flex and thus can cause binding.
  6. Chad Beck
    Feb 14, 2020
    You may have just figured out my issue, Thank You!! The stabilizers was down when I lowered the top on the camper. I am going to perform maintenance on the wiffletree and check and grease all pulleys.
  7. silvermickey2002
    4,760
    534
    Sep 11, 2008
    Morris County, NJ
    Hopefully that's the issue and maybe some maintenance will help!
  8. jmjub@msn.com
    jmjub@msn.com New Member
    Nov 13, 2016
    I have a 2004 fleetwood Utah as well. When I crank it up the wiffle tree hits the steel cover and makes a popping sound as I crank it up. I have checked the pullies and greased everything. Just can't figure it out.
  9. Coulter Wood
    Coulter Wood New Member
    Sep 27, 2018
    I had this issue, and it turned out that the chain had been stretched over the years, so it was loose. Had a shop remove a link in the chain, and it solved the issue. Good luck.
  10. Del Kelso
    Del Kelso New Member
    Jun 11, 2020
    in addition to excellent video's on YouTube (search for Pop Up Camper Pro), i have attached a copy of the Coleman service manual and a DIYer's write-up on replacing cables. somewhere in all of this is your answer and even if you can't do the work by yourself, you will have a much better idea what the service guy is talking about.
    lastly, once you get it figured out, i would be very interested in hearing about the solution / fix.
