Camco curved leveler
Discussion in 'Leveling Your Camper' started by Dstinnett875, Jul 3, 2020.
  1. Dstinnett875
    Dstinnett875 New Member
    25
    22
    May 25, 2020
    Huntsville AL
    Anyone try the Camco curved leveler? I just got a jayco pop up and thinking of giving it a try. Screenshot_20200703-115405_Chrome.jpg
  2. Bradley E Dixon
    Bradley E Dixon Member
    53
    73
    Jul 1, 2019
    Minot, ND
    I use the ANDERSEN version with my pup X2. Works great!!
    wusthof, Sjm9911, DiamondGirl and 2 others like this.
  3. Raycfe
    17,005
    2,587
    We also use an Andersen. As with and leveler you don't want it to slide or dig into the ground. A piece of plywood with a rubber mat prevents this.
    Andersens are strong. Maybe stronger than a Camco
    DiamondGirl and myride like this.
  4. xxxapache
    3,351
    1,340
    Been using the Andersens about 5 years. Some of the best camping gadget money that I have spent.
  5. myride
    myride Well-Known Member
    1,098
    556
    May 14, 2015
    Edmonton, AB
    ☝...same as above.
    DiamondGirl likes this.
  6. DiamondGirl
    DiamondGirl Well-Known Member
    621
    372
    Jul 2, 2016
    AZ Aliner
    Same as the others... Andersen has worked for us for many years. Very easy to use.
    Happy Camping...[ALPU][PUT]
  7. Sjm9911
    7,368
    4,751
    I cheaped out and got the camco ones. I needed 2 for the TT. Only had to use them once, so easy. One thing, as mentioned. Put something under them. Mine dug in for the long haul after being under the tires for a week. They sunk a bit so i could not remove them. So , i had to drive over them in order to remove them. The camco levelers did not break, so im surprised. They work. And there easy.
  8. Dstinnett875
    25
    22
    May 25, 2020
    Huntsville AL
    That's a good idea to put something under it. I was looking at the Anderson but noticed ther camco was cheaper so was thinking of going that route. Thanks to everyone whose replied.
  9. Rusty2192
    Rusty2192 Well-Known Member
    1,029
    455
    Jul 30, 2014
    Kentucky
    I have the Camco one too. I like that it’s a slightly smaller and lighter than the Andersen, but let’s face it, I got it because it’s cheaper. I added some grip tape to the bottom after reading reviews about it slipping. I also carry a 6” wide piece of rubber horse stall mat in case I need a little extra lift or am on soft ground.
  10. generok
    generok Well-Known Member
    2,845
    1,177
    Feb 7, 2013
    Anchorage, AK
    I have Andersen's for the TT and I really like them. I have run into an issue a couple of times. If I need over 2" of lift and I'm on gravel, they tend to sink, even with a mat. Thinking about putting a 2 x 8 in storage Bay for soft areas.
    CampingFamily1 likes this.
  11. Snow
    10,957
    1,618
    I know folks who had the Anderskn levelers and actually had to borrow a bag of my Lynx Levelers once because the Anderson's kept sinking on the wet ground.. I have a picture of it somewhere..
  12. Old_Geezer
    Old_Geezer Well-Known Member
    2,596
    259
    Sep 29, 2009
    Southwest PA
    Might work great on paving, not so much on grass or gravel. And I suspect a popup is a little more forgiving than a TT. I had one of the Andersons come shooting out from under the tire so close to my noggin that I felt the wind from it when I told her to back up more on wet grass. I gave them to my camping neighbor at the time. Give me 2X10's or give me death - P Henry.
  13. Dstinnett875
    25
    22
    May 25, 2020
    Huntsville AL
    The other thing ive thought about is building some step style ramps. Ive got alot of pieces of treated 2x6s from a fence project.
  14. Sjm9911
    7,368
    4,751
  15. jonkquil
    jonkquil Active Member
    658
    143
    Jul 20, 2009
    This is interesting. Since switching to a HW I haven't had any luck with my BAL. I've tried using it twice, on the last try DH & I started to have attitude with each other from frustration with it not working, I was seriously ready to throw it into the the bush, closely followed by DH! [LOL] When trying to raise it just seemed to cut into the tire at an odd angle (we were having to level by 4 inches at that site) it was also really hard to turn, we ended up using blocks & wood, took us 45 minutes to level, It made us look like right amateurs!! I'm wondering if the HW is a little too heavy for it because it worked great on my previous Fleetwood? Yesterday I ordered the Anderson leveler and it sounds like I might have to get creative with that if I have a 'soft' site.
  16. Sneezer
    2,343
    1,192
    The BAL is great as a Light trailer leveler. I have seen it stated that it is only designed for roughly 1,750 lbs, so guessing 3500 lbs pups are probably the limit. Yours has a gvwr of around 3,800 lbs, so it may very well be too heavy to easily use with the BAL. I have heard of some using two of them on bigger trailers though when there was room between the tires, so take it with a grain of salt.
    Is the screw properly lubed? I found with mine that keeping it lubed helped immensely.
    When/if I make the move to a hybrid or TT I will be going to an Anderson style due to the increased weight and dual axles. I would also plan on getting a horse mat remnant and using that under the Anderson on soft sites, I think that might help and the rubber should prevent it from skittering away when you try and pull up on it.
  17. CampingFamily1
    CampingFamily1 Well-Known Member
    959
    298
    May 12, 2007
    Minneapolis/St. Paul, MN
    This is my concern. We always camp on gravel. If we have to gt out a board to go underneath this leveler, then we might as well use boards. We've gotten pretty good at guessing how far off we are from level and how many boards to use.
    durhamcamper likes this.
  18. Sjm9911
    7,368
    4,751
    The boards aren't easy on duel axels, i forgot to put the boards under the levelers again last trip and just ran over the levelers again. So far so good, lol. Tougher then i thought.
  19. Steveo4090
    Steveo4090 Well-Known Member
    686
    614
    Jun 26, 2020
    Lancaster PA
  20. Snow
    10,957
    1,618
    I carry 1 board with us, that gets used under the lynx Levelers when ever we park on gravel sites or rutted uneven ground..
