Camp Stove
Discussion in 'Propane - Got Gas' started by smb985, Oct 22, 2019.
  1. smb985
    smb985 New Member
    Sep 11, 2017
    We have a 1997 Rockwood. The original stove works fine. We are wanting to use a "Coleman" stove as a backup. I have the correct hose for the stove. A quick connect. There is not enough pressure to keep the "Coleman" stove lit. If the original stove works, am I looking at a possible pressure issue or clogged line? There is a hookup outside and inside and both do not have enough pressure to keep it lit. There is a regulator at the tank. Any info would be appreciated.
  2. McFlyfi
    McFlyfi Well-Known Member
    575
    292
    Aug 1, 2014
    Thousand Oaks CA
    The quick connect is is the tip off- it's low pressure- 11wc (water column), less than 1 psi. This is the design, not a flaw or obstruction. If you want to use the outside port, you'll need to find a low pressure stove.
    Coleman/Fleetwood had a separate high pressure line that you can connect regular stoves/bbq's to.
    Quick connect = low pressure
    Screw connection = high pressure
    Rusty2192, Arruba and Sjm9911 like this.
  3. tombiasi
    6,008
    1,527
    +1
  4. smb985
    smb985 New Member
    Sep 11, 2017
    Thank you so much.
  5. rabird
    7,398
    591
    N. TX
    this type of tee will allow you to connect the 20lb propane container to the trailer leaving a connection for the coleman stove
    here or here to with either type of hose connection for the stove.
  6. p
    p Active Member
    576
    150
    Jun 9, 2014
    Or.. get a Coleman road trip BBQ and for ten dollars you can convert it to use a lp connect on your trailer. U caneed then buy an attachment for the burner so that u can use pots on the BBQ. Save even more money and get a used Coleman.
  7. smb985
    smb985 New Member
    Sep 11, 2017
    I think I will look into a high pressure hose since we also have a big buddy heater. Thanks again.
  8. dbhost
    dbhost Well-Known Member
    814
    325
    Sep 19, 2018
    League City, Texas USA.
    You need a high pressure hose for a Coleman propane stove.
    FWIW, You don't need any hose if you use a Coleman gasoline stove like a model 424...
    kcsa75 likes this.
  9. Anthony Hitchings
    1,547
    802
    Mar 2, 2019
    Which is why some interior stoves can be carried outside and plugged in to the exterior low pressure port (as was/is true of our Aliner)
  10. sleach
    697
    166
    May 17, 2014
    Boulder, Colorado
    Having travelled in trailers with a stove that can be connected to the out side, and trailers using a wholly separate stove, I much prefer the separate stove, whether fueled by propane or white gas. Often set up to cook outside, away from trailer, setting the stove on end of USFS, etc. picnic table, or on our rollup table.
    dbhost likes this.
