Camper flooring glue info needed
Discussion in 'Camper Restoration Projects' started by JOlvera, Apr 2, 2017.
  1. JOlvera
    JOlvera New Member
    Oct 20, 2016
    My girlfriend and I are redoing our 1991 Coleman popup flooring and need input. We have vinyl plank flooring and would like to glue it down for extra support. We ripped out the old vinyl sheet flooring, but some of it is still stuck to the plywood floor. What type of glue would you suggest we use to help the new flooring stick to what's left of the vinyl AND the plywood? We are located in Indiana so temps vary between 90s in summer and single digits in winter. We also get plenty of rain and humidity so moisture is another concern. Thanks in advance!
  2. Orchid
    Orchid Sharp Shootin' Grandma
    5,819
    2,702
    May 8, 2011
    Florida by way of WV and MD
    I can tell you for sure do NOT use Gorilla glue!
    I used it successfully in a previous camper, where I laid the tile over the old floor. Tried it with our current one, which we ripped up the old linoleum and it swelled up like spray foam insulation. :shocked:
  3. bigmajestic
    bigmajestic New Member
    24
    Nov 15, 2016
    South Mississippi
    Your local home store will have a variety of vinyl adhesives. Some you apply with a trowel and you can even get it in a tube that you use with a caulk gun. I laid down a vinyl sheet in mine and used liquid nails construction adhesive and spread it with a trowel. It's holding very well. Read the directions of the glue, some you have to let set for 10-20 minutes to let it become tacky. Hope this helps. Hint, if you ever have to do it again, leave the old vinyl floor down and trim any loose pieces away and lay on top of it, glue sticks really good to a smooth surface, not so well to OSB.
    Hope this helps.
    Orchid likes this.
  4. theseus
    theseus Centerville, OH
    2,896
    441
    Feb 6, 2007
    Centerville, OH
    I redid the stepper door on my coleman with vinyl wood plank. I can tell you construction adhesive works very well..
  5. Cameron
    Cameron Member
    37
    Mar 24, 2017
