Camper stove
Discussion in 'General Camping Discussion Forum' started by firepit, Mar 23, 2020.
  1. firepit
    firepit Well-Known Member
    1,051
    1,417
    Feb 26, 2020
    Nebraska Go Big Red
    How many of you have actually cooked on your stove inside your camper?
    I have never used mine on my last two pop ups
    Even if its raining i cook under the canopy.
  2. burtonfamily101
    burtonfamily101 Member
    53
    19
    Aug 8, 2017
    Same ive never used it, lucky enough my is one the removable ones that you can mount outside. I just always leave at home and use the campchef oven or grill depending on how many people I camp with.
    Melissa Freeman likes this.
  3. bheff
    bheff Well-Known Member
    1,504
    922
    Feb 24, 2011
    NW Arkansas
  4. Dingit
    Dingit Well-Known Member
    1,132
    616
    Mar 8, 2017
    One way that my popup trailer is an upgrade from my popup truck camper is the stove. The TC has a 2 burner cooktop. It is cramped and low power and I use it (but will often set up a camp stove on a picnic table outside). The trailer has 3 burners and an OVEN. I use them. I also use the flop-out stove on the outside of the trailer.
    Don't ask me to face the morning cold without a cup of coffee in the morning. Just don't. Coffee first, THEN going outside.
  5. Arlyn Aronson
    Arlyn Aronson Well-Known Member
    1,630
    1,131
    Jun 11, 2014
    Houghton, MI
    We "cook out" as much as possible. Mostly on a picnic table or a table we bring. Porkies fall camp c (DL).jpg
  6. roybraddy
    roybraddy Well-Known Member
    2,389
    926
    Mar 23, 2016
    King George, Virginia
    same here very seldom use the stove top...
    I have the COLEMAN ROADTRIP Grill setup outside at a right angle to the POPUP trailer... This uses the 1lb canisters.. Works great for us...
    google image
    Quarters inside the POPUP is just to small to deal with a stove top for us...
    Having the road trip Grill that needs the 1lb canister makes me have enough stock on-hand to run my coleman heater when needed...
    Roy Ken
  7. generok
    2,896
    1,276
    Feb 7, 2013
    Anchorage, AK
    I used mine inside when the weather was unpleasant, and outside on the side of the rig when it wasn't. I had no real issue using it inside though.
    arge and Thomaso Cieslako like this.
  8. bheff
    1,504
    922
    Feb 24, 2011
    NW Arkansas
    Bought 2 of the Coleman Excursions....great little grills. 20200224_151821.jpg
    Karen Gay and Sjm9911 like this.
  9. roybraddy
    2,389
    926
    Mar 23, 2016
    Pretty neat... Hadn't seen them before...
    I need to get a new cover for mine... Got two or three different cooking tops in a bag...
    Roy Ken
  10. kitphantom
    12,405
    1,394
    When we bought our first popup, we assumed we would never use the stove (& thought that we would use the sink). On the contrary, we found that having an inside alternative to our camp stove was a huge step up. Even just to heat water or do a simple breakfast on a chilly morning, or cook supper inside out of the wind we can encounter, was wonderful. (That sink proved to be pretty much useless, so we remove it in the two popups we had.) We also were able to use the inside stove in the first pup during severe fire restrictions, when only LP stoves were permitted. We didn't have one, so used the pups stove; we have not encountered another restriction quite so severe.
    Our cooking supplies, including food and cooler, all stayed in the tow vehicle.
    We were able to set up an outside cooking area under the awning on our second pup, so tended to use that a lot. With our current small TT, we do cook inside more than we did with the pups. We have a fridge that does work well, and we have a sink that is useful (including fresh & gray water tanks, plus hot water tank), so that's one reason. Our season is longer than it was with the tents and popups, and we do a few more overnight stops, when it's just easier to cook inside than set things up outside.
  11. Yacoma99
    Yacoma99 Member
    51
    36
    Mar 25, 2019
    We tend to cook outside more than inside the camper. Our current outdoor kitchen is an old school Coleman 3 burner stove, and a Blackstone griddle.
    southern gal and Becky Joppich like this.
  12. fourhallatts
    fourhallatts Well-Known Member
    1,108
    411
    Jul 18, 2015
    North Syracuse, New York
    We removed the sink and stove in our pup. It was not in good shape and we needed the room (ours is only an 8 ft. box). We cook outside either on our Coleman Roadtrip grill or over our campfire.
    Becky Joppich likes this.
  13. firepit
    1,051
    1,417
    Feb 26, 2020
    Nebraska Go Big Red
    I like the can cooker for soups...The pit boss table grill for steaks...And electric cook top for breakfast.
    Burgers and dogs go right on the camground fire pit/grill.
  14. kcsa75
    4,221
    2,208
    Sep 9, 2013
    Kansas City
    DW used the cooktop in the Pup all the time. She likes to cook so we also bought a counter top oven that should would use to bake pies and stuff. Now with the TT we have a three-burner range with oven and a built-in microwave. Still have the counter top oven that we normally set up outside and portable gas grill for grilling meat.
  15. Rusty2192
    Rusty2192 Well-Known Member
    1,035
    460
    Jul 30, 2014
    Kentucky
    I “cooked” inside for the first time this last trip a few weeks ago. Rain won’t push me inside but sub-freezing temperatures may. I used the stove inside to heat water in a kettle for coffee and ramen and used a stovetop toaster for bagels and reheating pizza for my son.
  16. Sneezer
    2,391
    1,228
    I removed the stove. Replaced the countertop as well since mine had a huge hole for the stove to sit in. Tried to use it outside but was less than impressed. Cut off the hose and modded it onto my Coleman road trip to work off the low pressure port.
    Now I use a camp chef weekender, Blackstone single burner griddle, Weber Q1200 grill and a camp chef oven for my outdoor cooking needs. All my cooking is done outside anyway.
  17. firepit
    1,051
    1,417
    Feb 26, 2020
    Nebraska Go Big Red
    The pit boss is my favorite...Uses hardly any charcoal and the built in fan and cover is a nice feature.
  18. Arlyn Aronson
    1,630
    1,131
    Jun 11, 2014
    Houghton, MI
    I should have included they we cook most of our main dishes over the camp fire. Breakfast is on the white gas stove.
  19. FARfetched
    FARfetched Well-Known Member
    744
    420
    Nov 22, 2018
    Sector 706, Planet Georgia
    Heating up a kettle on a cool morning in the pup is the way to go. Warms things up inside, and what hot water doesn't go into a French press for coffee goes into a pump pot for other warm drinks and/or dishes.
    Karen Gay and kitphantom like this.
  20. Pcolawinger
    Pcolawinger New Member
    Feb 8, 2020
    I will only use the camper’s stove to boil water, as I dislike food smells lingering inside...outside, I use a Camp Chef stove with built in oven. The burners are high temp and the oven gets between 350° and 400° And is big enough to bake biscuits and such, plus all the heat stays outside where it belongs... B6A89C58-B9E1-46A1-9B24-FD43EAA651DC.jpeg
