Camper sway?
Discussion in 'Miscellaneous Repairs & Maintenance' started by mrootes, Jul 9, 2011.
  1. mrootes
    mrootes 2009 Rockwood Freedom 1940LTD
    223
    Mar 4, 2009
    Noblesville, IN
    Were out camping right now and I have a small concern. Once cranked up and the awning out with the door down, and everything level, the top of the pup seems to have slightly swayed so it makes the door not open. Is the awning making this happen since out awning posts fasten to the camper rather than rest on the ground?
    I'm sure the camper is level but why is the top leaning some? Our door isn't working properly as a result.
  2. Unstable_Tripod
    14,279
    39
    May 20, 2008
    Seattle, Washington
    I think the roof could be pulled slightly out of plumb by the awning hanging on one side like that.
  3. Flyfisherman
    Flyfisherman New Member
    3,682
    Mar 4, 2003
    Shallotte, North Carolina
    Don't know about awnings poles that attach to the camper but where those poles are straight to the ground and then the awning tied off to something for security too tightly, has been known to pull the roof off center.
  4. NYgranny
    NYgranny New Member
    584
    Aug 16, 2006
    western NY near Rochester
    It always seems to me that our roof lists to the awning side when the awning is deployed, but we can still open the door. Is your roof up ALL THE WAY? Maybe an extra , even partial crank will give you enough room to open the door? I'm not sure---just my [2C]
  5. cico7
    cico7 Friend request denied.
    206
    Jun 21, 2011
    I read this thinking you should not be going down the road with the awning deployed until I got to the part about opening the door. ... I am thinking the awning is pulled down too tight pushing the frame down against the top of the door.
  6. rabird
    6,919
    399
    N. TX
    not sure what your door issues are.
    I tighten my Shepard poles to reduce roof movement.
  7. papachaz
    papachaz New Member
    2,821
    Jun 26, 2011
    maybe you need to check the roof adjustment? when raised all the way, each corner is supposed to be the same height, well there are acceptable differences. i think they vary from one make to another, but i'd check that too
