Camping Alone
Discussion in 'Lift Systems' started by Becky Roque, Jun 1, 2020.
  1. Becky Roque
    Becky Roque Member
    47
    58
    Mar 15, 2020
    Redlands, ca
    My pop up has to be lifted manually, usually not an issue except I’ll want to go alone sometimes and I can’t lift my top alone. I was thinking a jack of some sort??
  2. soflopopup
    soflopopup Member
    65
    74
    May 26, 2020
    Miami
    Can you use a drill? We use one for the stability legs.
  3. bheff
    bheff Well-Known Member
    1,504
    930
    Feb 24, 2011
    NW Arkansas
    What popup do you have? Why is popping it alone an issue?
    kitphantom and firepit like this.
  4. firepit
    firepit Well-Known Member
    2,547
    4,009
    Feb 26, 2020
    Good question...A impact is a option but i wouldn't run it all the way on a drill.
  5. Jimbow
    Jimbow Well-Known Member
    1,839
    403
    Nov 30, 2012
    Without knowing what aspect is causing an issue it's difficult to help.
    Rik Peery and kitphantom like this.
  6. bheff
    1,504
    930
    Feb 24, 2011
    NW Arkansas
    Drill is good, impact is bad.
  7. soflopopup
    soflopopup Member
    65
    74
    May 26, 2020
    Miami
    I assume she’s saying that having to manually raise it by herself is quite a workout and not something she can handle by herself. Using a drill until right near the end and then using hand crank to finish it off would be a good fit, unless something mechanical is preventing it from lifting.
    jelzim likes this.
  8. Rey-Pop-UP
    Rey-Pop-UP Member
    54
    60
    Jan 31, 2020
    Sacramento, California.
    A drill with the right socket attachment will do the trick. Good Luck!
  9. jmkay1
    7,060
    4,119
    Im a single female and go out by myself all the time. Would you be able to manage the other aspects of bringing your popup, like putting in the shephard poles and lifting the gally sink? For me the raising the roof was exhausting, but doable with rest. However lifting the gally sink was heavy and at the time my upper body strength wasn't there. Nothing like doing strength training exercise just to go camping. Now I can handle everything myself, but it was work to get my body ready.
    HappyFamily and kitphantom like this.
  10. firepit
    2,547
    4,009
    Feb 26, 2020
    My Dewalt drill wont touch mine ...But i have rooftop ac..Even so the wife can crank it up.
    My guess the OP has some injury limitations or has a old stiff pop up.
    She needs to give us some more info.
  11. Becky Roque
    Becky Roque Member
    47
    58
    Mar 15, 2020
    Redlands, ca
    It wasn’t given to me with some way to raise it other than lifting one side up and using a locking bar to keep it up then lifting the other side
  12. firepit
    2,547
    4,009
    Feb 26, 2020
    There should a crank arm sticking out on front or back where you attach a crank handle to lift it up or down.
    My guess the cables are broke...If not you can research the model and look for a replacement crank attachment/handle.
  13. Becky Roque
    Becky Roque Member
    47
    58
    Mar 15, 2020
    Redlands, ca
    It’s not a crankable pop up! I’m not sure it ever was...there’s no cables it’s just a pull up.
  14. Jimbow
    1,839
    403
    Nov 30, 2012
    What brand and model?
    firepit likes this.
  15. jmkay1
    7,060
    4,119
    Yeah that is an OLD popup. They only had external lift arms back then. I have no clue how to help you in this case.
    Indiobravo and Becky Roque like this.
  16. bheff
    1,504
    930
    Feb 24, 2011
    NW Arkansas
    Someone will be along with experience with that type of lift. My limited understanding of those types is it uses brute force to raise.
    jmkay1 and firepit like this.
  17. firepit
    2,547
    4,009
    Feb 26, 2020
    Ok i see now...That is out of my league and i may be totally wrong...But that has modified or so old they made them that way.
    I have never seen that before....But rest assure someone on here has and help you more.
  18. firepit
    2,547
    4,009
    Feb 26, 2020
    There has to be some kind of cheater bar or tool to aid in setting it up.
    Pretty wild none the less.
  19. firepit
    2,547
    4,009
    Feb 26, 2020
    Previous owner/owners...Check for title if it has one...Paperwork? registrations....Find a model number and make and hit the computer
    and start searching for info.
  20. tombiasi
    6,673
    2,239
    I would like to see the kind of popup that was designed to be put up that way.
    firepit likes this.
