Camping Alone
Discussion in 'Lift Systems' started by Becky Roque, Jun 1, 2020.
  1. Becky Roque
    Becky Roque Member
    47
    58
    Mar 15, 2020
    Redlands, ca
    I posted a picture
  2. firepit
    firepit Well-Known Member
    2,546
    4,006
    Feb 26, 2020
    I have never seen one...And if it is backyard engineered they did some serious thinking on it.
    The picture does appear to look factory if you blow it up.
  3. Becky Roque
    Becky Roque Member
    47
    58
    Mar 15, 2020
    Redlands, ca
    Yeah it’s not too bad, very simple with two people, but not simple alone!
    Kyle R Thorson likes this.
  4. Jimbow
    Jimbow Well-Known Member
    1,833
    398
    Nov 30, 2012
    Becky Roque likes this.
  5. Sjm9911
    10,751
    8,136
    Not much help, but get a six pack and ask the neighbors to help. I was thinking some kind of bar that attaches to the sizzor style lift so you have some kind of levrage and can use your body weight to lift it. Other then a rough idea, i got nothing.
    kcsa75 and Becky Roque like this.
  6. bheff
    bheff Well-Known Member
    1,504
    930
    Feb 24, 2011
    NW Arkansas
    Toedtoes likes this.
  7. bheff
    1,504
    930
    Feb 24, 2011
    NW Arkansas
    OP, your popup looks to be in great shape for its age. I remember a person made a leverage bar for his A-liner. I'll see if I can find the video. Maybe fabricating a similar leverage bar would help. BRB
  8. bheff
    1,504
    930
    Feb 24, 2011
    NW Arkansas
    Found it....wonder if this idea couldnt be used on your lift arms?
  9. Becky Roque
    Becky Roque Member
    47
    58
    Mar 15, 2020
    Redlands, ca
    I was thinking similar thoughts! But having a six pack on hand sounds hood too!
  10. Toedtoes
    Toedtoes Well-Known Member
    2,846
    2,822
    May 28, 2018
    A jack would be hard to work - you'd have to use 2x4s along with it and the jack would be real wobbly.
    It's an odd working and most solutions I can think of would be iffy trying to do solo.
    But as I'm thinking, maybe you could add a hydraulic strut (like for hatchbacks) and install it so it will help lift. It doesn't need to do all the work, just enough to take the full weight off you.
    Tom Jordan likes this.
  11. Toedtoes
    2,846
    2,822
    May 28, 2018
    Since her roof goes straight up, that wouldn't work as there wouldn't be any leverage to work with.
  12. neighbormike
    3,554
    4,310
    Oct 6, 2012
    WI
    You could definitely use a Jack... just be prepared to offer him a meal for his efforts! [:D]
    1380ken likes this.
  13. bheff
    1,504
    930
    Feb 24, 2011
    NW Arkansas
    Use it on the lift arms. They pivot in the middle. But it may put too much pressure on a single corner.
  14. kcsa75
    5,253
    3,280
    Sep 9, 2013
    Kansas City
    A six pack is always a good idea.
  15. Rik Peery
    Rik Peery Well-Known Member Gold Supporting Member
    1,628
    2,194
    Jun 15, 2018
    Virginia
    Who goes to a place & just orders an appetizer...make it a case [8D] [CB][CB][CB][CB][CB][CB][CB][CB][CB][CB][CB][CB] x 2...
  16. RockyRoo
    6,626
    257
    Jun 8, 2012
    Lol. Wow, ya’ll are making me feel old and I am only 48. That was a common system in the 70’s. Our Krown had heavy springs under the trailer attached to the lift arms to help with raising and lowering. It still could be a bit of a challenge but maybe check and see if you have some under there, they were pretty beefy. If not, but you see spots that they could belong then you might need to figure out a replacement setup to help.
  17. WrkrBee
    WrkrBee Un-Supported Member
    6,569
    3,461
    I thought it was a hood idea. Hood fits. I wonder if it was meant to be hood, or good.
  18. Rusty2192
    Rusty2192 Well-Known Member
    1,154
    572
    Jul 30, 2014
    Kentucky
    You could rig up something like this. You’d just need one to lift one side then move to the front. Just be careful where you hook it to make sure it’s nice and solid.
  19. Sneezer
    2,856
    1,691
    Palomino used external lift arms for years. I think they stopped sometime in the 1980s. I don't have much to offer though, having never used that kind before.
    Is that an old Shasta pop up? They used those arms. It looks very similar to the C&R system that you can buy as a kit as well. Does yours have functioning springs still in it? I think they had some strong ones that helped when pulling it upright. Maybe they are worn and need replaced?
  20. mpking
    mpking Well-Known Member
    1,460
    433
    Jun 17, 2014
    Raynham, MA
