Camping World says I need $1215 in repairs.
Discussion in 'Miscellaneous Repairs & Maintenance' started by Luce1995, May 6, 2019.
  1. Luce1995
    Luce1995 Member
    40
    Apr 28, 2019
  2. Luce1995
    Luce1995 Member
    40
    Apr 28, 2019
    I asked for a detailed invoice and there’s some fishy charges. I’m disputing them.
    Blackripley likes this.
  3. Luce1995
    Luce1995 Member
    40
    Apr 28, 2019
    The inspection was $285, but you are right—it’s not adding up. I was able to track down a local man who restores vintage campers, and he can work on mine for much less.
    1380ken, eoleson1 and Sjm9911 like this.
  4. Sjm9911
    7,388
    4,775
    For inspecting the pup.
    Luce1995 likes this.
  5. Luce1995
    Luce1995 Member
    40
    Apr 28, 2019
    $285 for inspection, yes. It’s 21 years old and I want to be sure of it’s roadworthiness before I take it on a 4000 miles trip.
  6. Blackripley
    Blackripley Active Member
    217
    161
    Jul 21, 2018
    Goleta Ca
    In hindsight $285 for inspection is not all that bad, especially if you are not familiar with campers. But for that expense I would expect a full written report that covered EVERYTHING according to their website your report should include:
    45 Point Inspection We will check the current condition* of:
    ELECTRICAL
    Hot Skin Test
    110V-Circuits-Polarity
    12V-Circuits
    Batteries-House/Engine
    TV Antenna Operation (Booster)
    Converter Output
    Converter Charge
    All Exhaust Fans
    Smoke Detector
    Power Cord Inspected
    Inverter Output
    Microwave
    AUX GENERATOR SYSTEM
    Oil Level
    Muffler System
    Auto Change Over-Operator
    Run Test - Hertz/Volts
    PLUMBING
    Check System for Leaks
    Water Pump Operation
    Toilet Operation
    City Water Intake-CK Valve
    All Drain Cocks
    Seal on Termination Cap
    L.P. GAS SYSTEM
    L.P. Leak Detector Test
    L.P. Hose(s) Condition
    L.P. Leak Down Test
    Leak Check System
    Set Regulator
    APPLIANCES
    Stove/Oven Temperature
    Refrigerator Operation
    Furnace Operation
    Water Heater Operation
    Roof Air: Front/Heat Strip/Filters
    Roof Air: Rear/Heat Strip/Filters
    EXTERIOR
    Breakaway Switch Operation
    Brake Control
    Tire Condition - Visual
    Roof Condition
    Vents/AC Shrouds
    Entrance Door-Gaskets
    Windows: Gaskets, Crank Handles
    Tongue Jack
    Antenna Condition
    Wiper Blades
    Shocks/Springs
    Exterior Lighting
  7. DesertRed
    DesertRed Member
    88
    Mar 28, 2017
  8. Luce1995
    Luce1995 Member
    40
    Apr 28, 2019
    I found a local independent repair person. I hate that I’m stuck paying $175 for the wheel bearing pack, but I know better now than to go with Camping World. I’m so grateful for everyone’s input!
  9. Halford
    Halford Well-Known Member
    3,563
    569
    Sep 28, 2011
    Santa Clarita, California
    The popup does NOT have most of the features in the 45 point inspection...
    Blackripley and xxxapache like this.
  10. theseus
    theseus Centerville, OH
    2,896
    441
    Feb 6, 2007
    Centerville, OH
    That would be a great inspection if you had an RV. 75% of that list doesn’t apply to a PUP.
  11. GatorChamp44
    GatorChamp44 Active Member
    152
    40
    Mar 16, 2017
    Were the tires radial at least? I hope so. Also, most of the other stuff is easy to replace on your own. Look up things on here or on youtube. Even the propane sensor.
  12. epcotisbest
    epcotisbest Active Member
    118
    75
    Feb 12, 2019
    Expensive lesson learned, but now you know. Local tire place near us charged $15 per side for bearing repack, or $30 total. Hard to complain about that price, and they do good work.
    As for CW, there is one about 30 miles from us, and we don't even slow down and wave when we go by. I tried to buy a new camper from them several years ago and we were in the office filling out the paperwork when they started adding on a bunch of ridiculous fees to the advertised price. They even wanted to charge me extra because I did not want to finance the camper. I laughed out loud, got a little angry and walked out. The salesman called me a couple of times, but I tried politely to explain how I would not be back in, and have not.
  13. rabird
    7,408
    595
    N. TX
    I was gonna suggest a traveling/roving RV person or even a hanyman.
    I hope the new guy works well.
  14. tfischer
    tfischer Well-Known Member
    4,037
    1,515
    May 21, 2014
    New tailight is like $20 on Amazon. Install it yourself for free and a $4 tube of silicone. It's not rocket science, or even a little bit hard.
    I had to replace tires last year and found it cheapest to just order new wheels from eTrailer. Cost less than $150 shipped for radials (would have been closer to $100 for bias). If you know how to change a tire on your car, and have access to a jack, again you install them yourself for free.
    The "inspection" is a joke. Just a way to drum up business.
    Propane tanks cost about $40 each for a (partially) full one anywhere that has propane tanks. Or buy a new empty one for about $30.
    All the other parts you can probably get on Amazon or eTrailer. You're looking at a few hundred in repairs, not a few thousand.
  15. LjohnSaw
    843
    50
    Jun 24, 2011
    Northern California
    What I do is pick up free propane tanks off of CraigsList. They are usually outdated. Then I swap them at Walmart (about the only time I go there) and get one that might be 2 months old (and 3/4 full) at about $14. After that, I go to a propane dealer and get them refilled with more gas for less money. Be careful at the swap tank places like Walmart. Nearly all the tanks had a quick repaint and were out of date, which is illegal. Refuse to take one of those, always find a new one.
    tfischer likes this.
