Can’t get socket on nut for leveler leg
Discussion in 'Stabilizing Your Camper' started by TheLight75, Jul 26, 2020.
  1. TheLight75
    TheLight75 Member
    53
    38
    Sep 8, 2019
    Eastern Massachusetts
    Hello,
    I’m in the process of replacing the leveler legs on our PUP. On each one there is 1 nut that is too close to the leg track to allow a socket over it. I was able to get 3 of them off using an open-faced wrench at a 90 deg angle but there is 1 that I can’t get loose because the wrench keeps slipping off.
    I hope one of the pro’s here can help me solve this challenge. :)
  2. tombiasi
    6,639
    2,209
    Do you have the correct wrench? Metric?
  3. Snow
    11,801
    2,380
    First.. they are stabilizers.. they are not to level the trailer..
    Second, if you can post a picture or two of the problem and problem area..
    kcsa75 and neighbormike like this.
  4. netslacker
    netslacker Member
    54
    45
    Jun 19, 2020
    If you’ve already rounded the edges of the nut it may be difficult/impossible to remove with an open wrench. A couple things that come to mind are: penetrating lubricant and vice grips. However, I’d only use vice grips as a last resort since they’re sure to ruin the nut but they may allow you to grip it if the nut is already rounded from previous attempts.
  5. TheLight75
    TheLight75 Member
    53
    38
    Sep 8, 2019
    Thanks for the suggestions! I was able to get it resolved a few minutes ago. The nut is 9/16" (not metric). The solution was to use my Dremel to grind down one outside corner of the socket so the socket wall was thin enough to slip between the nut and metal track. It came off nice & easy once I got it down to the right thickness.
  6. netslacker
    netslacker Member
    54
    45
    Jun 19, 2020
    Interesting approach! Glad you got it off.
    kcsa75 likes this.
  7. McFlyfi
    McFlyfi Well-Known Member
    754
    456
    Aug 1, 2014
    Thousand Oaks CA
    I had the same problem...I used a 9/16 open ended wrench vertically, turning it a 1/4 turn by clamping the handle in a vice grip. Took forever.
