Can I change my username? How?
Discussion in 'Web Site Features/Products' started by Rand LeMarinel, Jul 11, 2017.
  1. Rand LeMarinel
    Rand LeMarinel New Member
    Jul 11, 2017
    Colorado
    The thread title says it. Not sure if this is the right place to ask this questions but I thought I would try here after searching for an answer for a while.
  2. tombiasi
    5,434
    1,065
    Since the portal was "upgraded" your login name is your user name, no signs that will change.
  3. Leigh Anna Voigt
    Leigh Anna Voigt New Member
    Jul 22, 2017
    Also wondering this.
    I assumed that I needed to input my name and would pick a screen name later. I don't like the idea of using my real name.
    Rik Peery likes this.
  4. Strawhouse
    Strawhouse Well-Known Member
    1,394
    467
    Oct 4, 2015
    Muskoka, Ontario
    I don't know if you can delete your existing profile--perhaps someone else can answer that...
    in the meantime, you could just create a new profile under a new user name and use it from now on.
  5. Bowman3d
    Bowman3d Well-Known Member
    822
    297
    Apr 13, 2015
    LaLa land (SoCal)
    I had changed my user name in the old format. When they changed to the new format it changed back. I asked about changing it back. The answer was basically that there is no way to change it at this time. Like Strawhouse said your best bet is to just make a new profile.
