Can I replace the swing-down stabilizers with crank-downs on my 01 Coleman Taos
Discussion in 'Stabilizing Your Camper' started by qswv, May 1, 2014.
  1. qswv
    qswv New Member
    34
    May 30, 2010
    Hello!
    My swing down stabilizers are janky from a previous owner. Can I replace these 3 compromised stabilizerss with more secure crank down stabilizers, without welding?
    THANKS!
  2. jwrober
    jwrober Member
    183
    Feb 28, 2014
    Can you post some pics of how the existing are mounted? The answer is maybe depending on what the frame looks like and where you think you want to put them.
  3. efehser
    efehser New Member
    4,614
    Sep 3, 2012
    The short answer is yes. I used these.
    The slightly longer answer involves removing the old jacks. On my Jayco they are welded on, and removal is a PITA. I've heard Coleman bolted the swing downs on their campers which would make that a lot easier.
  4. rwilliek
    rwilliek New Member
    210
    Jan 21, 2014
    I did it! Great improvement!!! My Coleman had the swing down stabilizers bolted on, made removal fairly easy - one of the bolts spun inside the metal it was mounted to, but I got it.
    I used these:
    http://tweetys.com/crossframestabilizingjacks.aspx
    But found them for half that price....well worth the cost.
  5. qswv
    qswv New Member
    34
    May 30, 2010
    Sorry, I've never posted photos before. I see the insert photo icon, but I'm still not correctly inserting a photo. If anyone has any advice on how to do so, I'd gladly post some pix.
    The stabilizers are mounted with two bolts, so I assume I can remove them, but I'm not sure how any other stabilizer would fit. The current stabilizer array is two in the rear and one one the front (the other side is "stabilized" with the wheel jack)
    Thanks for any assistance!
  6. efehser
    efehser New Member
    4,614
    Sep 3, 2012
  7. Jayko
    Jayko Jayco 141J aka Big Bertha
    1,263
    17
    Jul 10, 2012
