Can I vent portable A/C exhaust thru screen?
Discussion in 'General Camping Discussion Forum' started by jweaks, Jul 20, 2018.
  1. jweaks
    jweaks Member
    40
    Mar 16, 2015
    Texas
    I bought a single-exhaust portable A/C unit. My little pup is SO limited in counter space options or zippers to run the big 6" exhaust tube thru. Do you think I can have the heat exhaust blow through the screen on the side of a bunked without issue (like the heat melting the screen)? Here are pics to see what I'm talking about.
    Setup idea from the inside:
    View without the hose from the inside:
    View from the outside:
    I would fill the triangle-ish bunkend screen cavity with a piece of reflectix with a hole cut out for the exaust tube.
    I realize it'd be best for the tube to protrude through a gap somewhere and end several inches away from the PUP, but every attempt to go through a zipper and/or velcro gap leaves huge, long gaping places all around it.
    Thoughts?
    lynnmarie0123 likes this.
  2. Halford
    Halford Well-Known Member
    3,563
    567
    Sep 28, 2011
    Santa Clarita, California
    any condensation? Check other areas that may allow for any openings.
  3. jweaks
    jweaks Member
    40
    Mar 16, 2015
    Texas
    It's supposed to be basically condensationless... evaporates the water which expells through the exhaust. Worst case scenario is it won't keep up, and I can run a 1/2 tube off of the optional drain. That won't be a problem.
  4. mstrbill
    mstrbill Active Member
    692
    146
    Mar 17, 2013
    Austin , Texas
    Why not just unhook the tenting and push the hose through. stuff some towels to seal up the gaps. I think this would work better and do this in my Niagara.
    lynnmarie0123 and jweaks like this.
  5. jweaks
    jweaks Member
    40
    Mar 16, 2015
    Texas
    Stuffing the tube down thru the tenting leaves such a gap, and feels so non-elegant, but maybe you're right that this is best, after stuffing towels.
  6. JPBar
    JPBar Well-Known Member
    1,873
    582
    Sep 22, 2016
    Texas
    Do you have a zipper where the bunk canvas attaches to the box canvas, near the post. Mine zips from the bottom to the top. Might try that . Just a different ideal. Good Luck.
  7. jweaks
    jweaks Member
    40
    Mar 16, 2015
    Texas
    No zipper there, so can't go through the "side wall". I'm considering the merits of this down thru the undone velcro at the bunk end. It's a very small PUP (see sig), so not a lot to work with.
  8. xxxapache
    3,260
    1,237
    I exhausted mine through screen for 8 years. No problems.
  9. kcsa75
    kcsa75 Well-Known Member
    3,866
    1,974
    Sep 9, 2013
    Kansas City
    Same here. What you're doing is exactly what we did. Worked like a champ.
    jweaks likes this.
  10. nineoaks2004
    8,040
    3,583
    Dukes, Fl
    It should not get hot enough to damage the screen. Looks like this should work for you Hopefully it will cool enough too.
    jweaks likes this.
  11. seldomseen380
    seldomseen380 Active Member
    433
    144
    Jan 12, 2007
    Canton, Georgia
    Just cut a hole in the roof and......
    Just Kidding..[8D]
    Rik Peery and jweaks like this.
  12. Overland
    Overland Well-Known Member
    367
    280
    May 1, 2013
    Bristol, Pa
    Personally I would consider finding a location on sidewall or floor to cut a 6" hole.. flange and screw on type caps when not in use.
    jweaks likes this.
  13. jweaks
    jweaks Member
    40
    Mar 16, 2015
    Texas
    Ran it for a few hours test run. Cooled off awesome in the evening. But that exhause hose is HOT, radiating big time. So, I'm thinking whatever path minimizes room exposure is ideal. Gonna cover it with some reflectix as well.
    terry1419 likes this.
  14. terry1419
    terry1419 Active Member
    669
    82
    Mar 6, 2016
    Streator, IL
    When I used to use the hose, I wrapped it with pieces of old blanket to reduce heat radiated back into the pup. Now I just eliminate the hose, put the AC on the counter and vent the heat right through an unzipped corner of the window and through the screen. Condensate hose not needed because mine exhausts the moisture along with the hot expelled air.
  15. Sneezer
    2,088
    933
    I found a perfect vent nozzle at Lowe's. They sell a stealthflow gutter downspout extension system. The starter kit included an adapter nozzle that goes from their flat tubing to a standard 3" hose. I wrapped the 3" section with some reflectix so it would fit snugly into the exhaust tube for my A/C. I have it exhausting through a side window on the dinette. The zippers seal up pretty well too. I still need to wrap the hose in reflectix though to keep the heat transfer to a minimum.
  16. lynnmarie0123
    lynnmarie0123 Active Member
    300
    54
    Jun 19, 2020
    Your pics are not opening for me
  17. jweaks
    jweaks Member
    40
    Mar 16, 2015
    Texas
  18. lynnmarie0123
    300
    54
    Jun 19, 2020
    Hmmmmm ok yes i didnt take that into consideration. How big in diameter is that hose?
  19. lynnmarie0123
    300
    54
    Jun 19, 2020
    Can i ask why hose is Going out up High and not down nearer to floor of bunk? Im going to do this... just trying to understand how :)
  20. lynnmarie0123
    300
    54
    Jun 19, 2020
    What make/model thank you!
