Can my pop up handle a long trip?
Discussion in 'On The Road' started by WP Mark, Nov 24, 2018.
  1. popup 61
    popup 61 Member
    40
    Jan 10, 2016
    Northeast PA
    Actually the best way is to get plastic/teflon pads to place between the leafs.
  2. JunieB
    JunieB Active Member
    331
    165
    May 8, 2018
    Central Florida
    If you would do 8, 100 mile trips over a period of time, you should be fine to do one, 800 mile trip. Stop often to check everything and the temp of your wheel hubs. I just routinely stop every 100-150 miles on any trip to reset my attention span, get gas, a cold drink, whatever.
  3. Haybale
    2,546
    441
    Aug 22, 2013
    San Diego via MN
    And how do you plan to get those between the leafs that are clamped together??
  4. Tumbleweed53
    Tumbleweed53 Member
    36
    17
    Sep 11, 2016
    Any spring repair shop will have replacement Teflon pads for that. Requires disassembly of the spring pack. Not really a hard job but time consuming. Some out of the ordinary tools may be needed. I have done this many times on leaf spring trucks and jeeps. Is it really worth it? I honestly don't know.
  5. mmpopuplvr
    mmpopuplvr New Member
    22
    Mar 8, 2017
    Good tips! And if the hubs are warm when you check....what does that mean/need to do?
  6. BikeNFish
    BikeNFish Well-Known Member
    4,138
    3,121
    Apr 24, 2017
    Maplewood, MN
    Warm is OK. Hot is not.
    I always check my hubs on all of my trailers. Sometimes one hub is warm while the other is not.
  7. Anthony Hitchings
    3,056
    1,809
    Mar 2, 2019
    Oakland, California
    M 12" wheels have done thousands of miles, no blowouts, two slow leaks that I swapped out for spare tire/wheel.
  8. Natureangel
    1,137
    356
    Feb 28, 2016
    Illinois
    Last summer I went from NE Illinois to Yellowstone in my 2000 Rockwood Freedom with out a single problem. Later that Summer on a short trip I had a leaf spring bust! I switched out all the springs so that won’t happen again!
  9. tzmartin
    tzmartin Not here for a long time but here for a good time!
    1,371
    710
    Sep 9, 2015
    Clayton, Georgia
    Yes, popup's can handle a long trip if they are in good shape. Hope your trip in 2018 went well!
  10. Goforit
    Goforit Active Member
    124
    187
    Jun 18, 2020
    GA
    I found that a good way to check your hubs and even your tire temperature is to get an "infrared temperature gauge". You can pick one up at Harbor Freight or get one off of Amazon. I keep it in my glove box. When I make a stop, I do a quick walk around, hit the tires and rims with the gauge. Overly hot rims maybe a bearing. Overly hot tire and your pressure may be low.
  11. New Old Jayco
    New Old Jayco New Member
    Sep 23, 2021
  12. UpNorth-John
    UpNorth-John Member
    96
    28
    Sep 4, 2010
    The simple (and obvious) bearing check is a great practice. I pull a 1975 pup from Michigan to W.Va., the East coast, Ohio & Iowa on a fairly regular basis (and quite a few short trips in Michigan). Every stop is a tire/bearing hand check. With 12" tires a little warm is okay, bearings should stay cool. I also check the hitch & chains. I would recommend re-checking wheel lug torque before a long trip...had one (then two) let go and tear the center out of a four-bolt wheel a few years ago on a bad stretch of road (that will really get your attention when the wheel departs at 55 mph! ;-). Fortunately there was no damage to the trailer.
    Sounds like you're on the right track with basic maintenance. Enjoy the trip!
  13. Haybale
    2,546
    441
    Aug 22, 2013
    San Diego via MN
    I am nearing the end of a ~4,500 mile road trip with a 1973 pop up and a 2000 4 cylinder car.... Is that long??
    NMroamer likes this.
  14. theseus
    theseus Living the Darkside... Silver Supporting Member
    3,359
    809
    Feb 6, 2007
    Centerville, OH
    You’ve done all the right maintenance on your pup. You are good for long trips.
    I took my 1966 Nimrod Capri on a 10000 mile trip in the 90s. No problems at all. Why? Because I made sure it was properly maintained.
    Haybale likes this.
