Can you help me identify battery type?
Discussion in 'Mystery Parts' started by 1Step, Jun 16, 2020.
  1. 1Step
    1Step New Member
    Sep 21, 2019
    San Diego
    Hello-
    Trying to setup my Renogy solar controller (Traveler voyager 20A) and don't know which battery type to select. Renogy states: "
    The Voyager provides 7 battery types for selection: Lithium-ion, LiFePO4, LTO, Gel,
    AGM, Flooded, and Calcium Battery.
    Included is a photo of my battery.
    I have a lot to learn.
    Thank you for your help!
  2. eoleson1
    eoleson1 Well-Known Member
    3,003
    1,220
    Jul 5, 2011
    Macomb County Michigan
    That picture is a flooded battery.
  3. pmt
    pmt New Member
    25
    May 29, 2018
    GTA, Ontario, Canada
    That's a standard flooded battery.
    If you haven't already, it might be a good idea to check the water levels and top up with distilled water before the season.
    Also, the next time you replace the battery, pick up a deep cycle battery - you'll get better performance over a starting battery.
  4. awdblazer
    awdblazer New Member
    18
    Apr 2, 2019
    charge it up first before you top it off with water though
  5. rabird
    7,402
    592
    N. TX
    don't overfill it!!!! Learn before you fill, distilled water, use protection! Clean the battery.
  6. Anthony Hitchings
    1,563
    814
    Mar 2, 2019
    In each cell add only enough true distilled water (from CVS) to get the bottom of the filling “tubes” inside the battery to form a curved cup in the water surface (a meniscus?)
