Can you leave the bedding on the bunk and close the camper?
Discussion in 'First Time & New Camper Owners' started by MommaStarbucks, Jul 10, 2012.
  1. MommaStarbucks
    MommaStarbucks New Member
    Jul 24, 2011
    Usually, we use normal bedding, not sleeping bags, and it's in the truck til we get there and set up. We stay our time, pack down, folding up the blankets and putting them on the table for easy retrieval.
    Come August I am planning a 3 day drive, 4 day camp, 3 day drive back and was wondering if i have to pack up the bedding everyday, or just leave it made?
    It's hard being a newb lol!
    TIA [:D]
  2. gketchup
    gketchup Member
    259
    Feb 23, 2012
    We have enough clearance in our roof to have 2" memory foam topper, sheet and quilt on our bed. Love not having to make the bed during set up!
  3. coloskibum
    coloskibum New Member
    Jul 9, 2012
    We leave the sheets on light blankets on our beds and only fold and pack away the heavy blankets/comforters. Top closes no problem.
  4. MommaStarbucks
    Jul 24, 2011
    Excellent news! So best thing to do is try it out and see if it wants to close... go figure. :)
    Thanks!
  5. kowboy311mi
    kowboy311mi New Member
    83
    Oct 5, 2011
    Should be fine. I know yhere is a few inches above the bunks under the ceiling. The canvas can't take up that much room.
  6. Unstable_Tripod
    14,279
    35
    May 20, 2008
    Seattle, Washington
    I think that most PUPs have a couple of inches under the roof and that should be enough for the bedding. I make the bed at home before I leave and for "out and back" local trips don't mess with it again until I get home. On long touring trips I bring an extra set of sheets and change them out every so often. I stop at a laundromat to do them along with the rest of the dirty clothes.
  7. pcfeld
    pcfeld New Member
    196
    Jul 11, 2008
    To test it you can put a empty tissue box in the bunk end and close it up. Once opened the box size will tell you how much space you have. When I tested mine DS#2 actually suggested a wooppy cushion which actuall worked rather well.
  8. qwed94
    qwed94 New Member
    225
    Mar 27, 2012
    Yea I keep my beds dressed and still close the lid
  9. Campit
    Campit EAT SLEEP CAMP
    1,638
    Sep 16, 2011
    I roll up the sleeping bags and fold the comforters,(I do this so I can air-out the sleeping bags and wash the comforters) but the foam pads stay on the bed. I don't think you'll have any problem. Go out, try and see if your top will close with the bedding. [;)]
    Campit
  10. AMomInLove
    AMomInLove New Member
    61
    Jun 26, 2012
    We have never tried this either -- bedding is removed/cleaned every trip and don't open trailer till a couple days before we go out again...
  11. shelmily
    shelmily Well-Known Member
    3,311
    290
    Jun 7, 2012
    Northeast Pennsylvania
    As others have said, I have a 2" topper sheets and a light blanket that is left on. I wash everything up before we go, make the bunks, and fold it down. So much easier to setup and take down at camp.
  12. kitphantom
    11,813
    889
    We sacrificed the ability to leave the bed fully made up when we got 2" memory foam. We leave the sheets on and take off the blankets. The blankets are folded a bit and travel across the middle of the bed, down the center line of the pup. That gives us enough space to fold in the tenting at the sides.
    This is still a bit of an improvement over the previous pup, where we had to be very careful not to catch the bedding on the bed slides; we had one sheet that ended up with a very large tear over time.
    [For us, folding the blankets is not a biggie, I tend to pull them all loose in my sleep so they need to be rearranged every night. Sleeping bags would have to be rolled up too, and the blankets and quilt are easier to pack than the bags would be - and we sleep better in real bedding.]
  13. papachaz
    papachaz New Member
    2,821
    Jun 26, 2011
    we always left ours on, then when we did the "open it back up to clean" (something we love about having a TT, no more of that) DW would strip the beds at that time.
    you should be able to, but i like the tissue box idea
  14. Buttermilk
    Buttermilk New Member
    217
    May 6, 2012
    When we get home, we put clean sheets on the beds, repack most of the stuff we need for next time and I make an inventory list of everything thats in the camper. Old people like me tend to forget what I put in there.
  15. Yellowkayak
    2,198
    Mar 13, 2007
    We would love to do that, but with the pillow toppers (TWO of them, yes its like sleeping on a cloud) and the sheets and blanket...its way to thick to close the top down....so we remove everything, put in giant vacuum bags and put away between trips.
    JJ
  16. Ted S.
    Ted S. Member
    856
    Dec 20, 2011
    We have 2 1/2" memory foam which we leave on and it is a bit of a job to close the lid. You have to pull down and slip the clamps on. The foam really compresses so I don't think it is a problem, but I wonder.
  17. Unstable_Tripod
    14,279
    35
    May 20, 2008
    Seattle, Washington
    Don't forget that those roof latches have threaded shafts and if the fit is just a bit off you can rotate them a turn or two to extend them. Just don't go so loose that the rubber seal between the roof and body fails to make a water-tight contact point.
  18. Bullfrog Bheer
    Bullfrog Bheer Active Member
    2,870
    Feb 19, 2010
    Central Wisconsin
    We do have sleeping bags on our bunks and unless we're taking them out to clean them, they always stay on.
  19. warwgn3
    warwgn3 Car Shows are 2nd only to Camping!
    246
    Feb 21, 2010
    All you people make me jealous!
    I have to make the beds (sheets and blankets) every time I set up camp. I prefer to do it right away, so I don't have to worry about it when I'm ready to hit the sack.
    When breaking camp, I have to stuff my bedding into the under bed storage cabinets, and then pull the mattresses onto the floor before I can fold my hinged (non sliding) bunks to close down my camper.
    I'd give anything to be able to open up my camper and have the beds already made.
  20. owner317
    owner317 New Member
    18
    Aug 5, 2011
    We don't leave anything on ours when we close it because when we tuck the "canvas" in, it lays on the beds. I don't want anything (tree sap/bird crap) on the outside of the "canvas" to lay on the sheets I'm about to curl up in. I always lay an old sheet down to cover the mattress while we're not using it and make the beds with fresh linens when we pop it up.
