Canopy rocks
Discussion in 'Boondocking' started by Casualaz151, Jun 22, 2019.
  1. Casualaz151
    Casualaz151 New Member
    Apr 27, 2019
    colorado springs, co
    I am doing a boondock this weekend and it seems that my roof rocks. Second time setting up and i dont recall it doing this the last time. Anyone have any ideas? I cranked and heard the clicks but still not sure.
  2. Sjm9911
    4,991
    2,640
    Depending on the wind they can rock. Not sure if yours is unusual or not. Some tie them off like awnings.
  3. BikeNFish
    BikeNFish Well-Known Member
    3,037
    1,930
    Apr 24, 2017
    Maplewood, MN
    Popup roofs always have some sway in them. It is designed in to allow some give in windy conditions, otherwise things will break. Securing the door usually helps with the sway as does setting up the canopy if you have one. It you are still worried about it, you can tie a line to the lift supports and secure them to a nearby tree if there is one.
  4. gladecreekwy
    751
    855
    Sep 25, 2016
    Jackson Hole
    Was it level?
  5. Casualaz151
    Apr 27, 2019
    Well it was until the rain came.
  6. gladecreekwy
    751
    855
    Sep 25, 2016
    Jackson Hole
    Mine seems to sway more if it’s not level
    8lugnutz and Flipped in NH like this.
  7. Sjm9911
    4,991
    2,640
    I have to ask.....how did the rain make it unlevel?
  8. Casualaz151
    Apr 27, 2019
    Its on the side of my house in the dirt so it sank a bit. Poor drainage.
  9. Sjm9911
    4,991
    2,640
    Ah , get a few smaller boards to sit the tires on. I also put some under the stabilizers. Will work well.
  10. Casualaz151
    Apr 27, 2019
    Yea i have the pads for the stabilizers but since this was just a "Dad...we want to sleep in the popup" set up i skipped that step. I shoulda known better.
