Can't find this 12v wiring harness anywhere
Discussion in 'Wiring' started by kcormier19, Apr 5, 2021.
Tags:
  1. kcormier19
    kcormier19 Member
    95
    39
    Sep 12, 2017
    massachusetts
    On most pop up campers there is a wiring harness where the black and white wire go from the base of the pup to the top of the pup. It will be feed through a small channel sewn into the canvas. It is usually located on the street side rear of the pup. There are two plugs on this wire, one at the bottom of the canvas one at the top. I am searching for a replacement wire and plug set and cannot find one for a 1999 Coleman Cheyenne. I tried Coleman Pop UP Parts with out luck.. There is a person on Ebay who sells just the clips so i could make my own harness but the wires need to be soldered and i cannot do that. Any idea where I can find the whole set up or at least the male and female clips that do not need to be soldered?
    Thanks in advance everyone,
    Kyle
  2. Anthony Hitchings
    2,222
    1,222
    Mar 2, 2019
    Oakland, California
    Soldering is dead easy - use resin core solder. Keep your options open.
  3. Kyle R Thorson
    Kyle R Thorson Active Member
    129
    108
    Aug 29, 2019
    Arizona
    I would try contacting colemanpopupparts.com and asking them. You can't be the first person to have to replace one of those. I know exactly what you are talking about and it seems like even if it is pulled from a used/donor unit it should be something they can get.
  4. JimmyM
    JimmyM Well-Known Member Gold Supporting Member
    3,083
    1,068
    Jun 5, 2014
    Franklin, MA
    Can you take some pictures of the cord plugs and the damage?
  5. kcormier19
    kcormier19 Member
    95
    39
    Sep 12, 2017
    massachusetts
    @Kyle- they were the first place I tried and Derek said they didnt sell them. From what he said, if worse came to worse, I could cut the lower and upper connectors that are there now and use any 12v connectors to make the new wiring harness.
    @Jimmy, I will take a picture tomorrow morning to post.
    Kyle R Thorson likes this.
  6. Kyle R Thorson
    129
    108
    Aug 29, 2019
    Arizona
    I gotcha, I didn’t know if you just searched the website and couldn’t find it. I would be interested to know if you find something that does work. I have an ‘06 Utah. Might come in handy some day.
  7. kcsa75
    4,712
    2,762
    Sep 9, 2013
    Kansas City
  8. Raycfe
    17,238
    2,830
    The would just use soldered connections
  9. Everett Bartlett
    Everett Bartlett New Member
    24
    Aug 2, 2020
    Southern Nevada
    31Grg64tppL.jpg Here is a picture of a plug assembly that you should be able to find at any auto parts store, possibly at Walmart, or Lows. You cut them apart, and use crimp on butt connectors. You should be able to do it in less than 10 min.
    MApopupreno likes this.
  10. Jkoht
    Jkoht Member
    40
    21
    Aug 10, 2020
    Are you missing the harness completely? In any event there are multitudes of crimp on connectors you could buy, and splice on yourself, or create a new harness. If it were me and the harness was missing I'd cut the plugs off the top and bottom and just put some new wire in between and use some crimp on butt connectors. Most hardware stores carry wires of varying kinds and dimensions, personally I've used solid copper low voltage thermostat wire in a lot of 12 volt applications. There's no major reason it has to use those factory plugs short of swapping out the canvas easily that I can see.
  11. kmbarreiros
    kmbarreiros Active Member
    172
    88
    Jun 17, 2014
    Fairhaven, MA
