Cant get water out of cassette toilet - ugh
Discussion in 'Camper Storage / Winterizing & De-Winterizing' started by backyarddad, Oct 28, 2013.
  1. backyarddad
    backyarddad New Member
    507
    Mar 25, 2013
    Hey all -
    I started winterzing, not sure if I am doing the "norm", but I blew the water out of all my lines, I did not want to use anti-freeze, but in my cassette toilet, I still have water in the overflow tube, it comes out little by little, but cant seem to get it all out, I have ran the toilet until the water is in holding tank - am I missing something?
    Thanks.
  2. nomorecoop
    nomorecoop Member
    454
    Jan 8, 2012
    I use a turkey baster to draw all the water out. Works like a charm.
    In case my wife reads this......I don't use the one we have in the kitchen [:(O] [:D]
  3. JeffR
    JeffR Member
    30
    Jul 8, 2013
    Hey backyarddad,
    I don't know if we have the same model cassette, but I pulled the sight tube off at the top and tipped it down to drain mine.
  4. nomorecoop
    nomorecoop Member
    454
    Jan 8, 2012
    Agree on the site tube...
    Sorry...I was referring to the water fill spout. Even with the tube drained, water still remains in the fill spout.
  5. Sumoman
    Sumoman New Member
    826
    32
    Mar 20, 2013
    Straw
    CATAPULTAM HABEO. NISI PECUNIAM OMNEM MIHI DABIS AD CAPUT TUUM SAXUM IMMANE MITTAM.
    2000 Land Rover Discovery, loaded with ARB and ready for the end of the world.
    2008 Fleetwood Evolution E3, loaded and ready for the end of the world.
    1967 Heckaman Manufacturing, "Phoenix" 18FT travel trailer.. Beginning of Mobile Man-Cave process.
  6. aslag
    aslag Pacific Northwest
    400
    Sep 8, 2008
    Pacific Northwest
    I use a small rubber hose (old automotive vacuum line) to siphon out the remaining water.
  7. kmh1596
    kmh1596 Wilbraham, MA
    5,362
    Aug 20, 2007
    Western MA
    You're doing it right, as far as tipping it down, but you need to introduce RV Antifreeze (non toxic) to both the water system and the toilet flush supply tank, or you'll be repairing more in the spring. Particularly in the pump and any low spot in the lines, water is still present, even after blowing them out. Best way is to blow them all out, drain the cassette like you have, then run RV antifreeze through it. If you have a water heater, be sure it is bypassed, as you will need 6 gallons just to fill that if it is not. I did my '10 Niagara with 2.5 gallons, and had I not been so liberal with making sure it was pure pink coming out of every drain and every tank, I may have gotten away with less.
    Good Luck!
  8. PaThacker
    PaThacker Well-Known Member
    1,374
    276
    Feb 11, 2010
    Poconos
    I remembered flushing antifreeze through out the cassette system repeatedly until the site glass was pink.
  9. kmh1596
    5,362
    Aug 20, 2007
    Western MA
    Same here, except if you pull the tube off, and aim it down (as OP did), it will drain 95% of what is in there. Then put enough Antifreeze so that you see pink in the siteglass, flush until it comes out pink, and you're done. Probably took 10 minutes, including waiting 5 mins for the flush reserve to drain when I tipped the site-glass out. In the Spring, use the AF to flush, or do the same and drain/refill it. NBD. ;)
    I wouldn't want to know what the valves cost in some of these toilets, let alone the process of getting to them and replacing. Antifreeze is cheap insurance.
  10. tenttrailer
    3,550
    532
    Jul 18, 2013
    Thornville, OH
    +1 - - -I then flush until no more water. - - - - - Then add about 2 cups of antifreeze to the holding tank and flush until I see pink. - - - - Then drain the remaining antifreeze out through the site glass back into the jug. good to go.
  11. backyarddad
    507
    Mar 25, 2013
    OKay - looks as I have to raise the Pup again! NOOOOO...when its up I want to go play but I can't!!
    Any idea how much antifreeze I will need?
  12. Campit
    Campit EAT SLEEP CAMP
    1,638
    18
    Sep 16, 2011
    [LOL] [LOL] [LOL] Man, I sure hope it's not the same one!
    Campit
  13. kmh1596
    5,362
    Aug 20, 2007
    Western MA
    For the cost of antifreeze (cheap, considering) I'd grab 1 gallon for the cassette, and 2-3 for the rest of the camper. You'll have some left over, but one cracked line or p trap will cost much more than extra antifreeze.
