Carbon monoxide detector
Discussion in 'Campsite Security & Safety' started by Mark60, Sep 25, 2021.
  1. Mark60
    Mark60 Member
    68
    60
    Aug 23, 2020
    TN
    Do most people install a carbon monoxide detector in there pop up if there going to use the furnace. I think mine has the propane leak detector but I don’t know if it does the carbon monoxide also. We are going camping this coming weekend and will need some heat at night and in the mornings. I’ve only tried my propane furnace out but never camped with it on while sleeping. I kind of have some reservations with it running while sleeping as All the exhaust come out on the side down low, it’s probably fine but the pop ups are probably not air tight.
  2. Sjm9911
    10,618
    8,000
    Get one , your propane detector may do both, but it should say it on the front. Get a combo smoke/co. That way your covered. Better off safe .
    theseus, rth3775 and xxxapache like this.
  3. davez26
    davez26 New Member
    Jul 19, 2014
    Agree, cheap insurance.
  4. BillyMc
    BillyMc Well-Known Member
    2,303
    1,632
    Mar 25, 2018
    My gas detector does both, but make sure. If you don't have a smoke alarm get one the also does CO and sleep well. I've never had a problem with fumes from the furnace. When battling strong winds I've had fumes from the water heater pushed in and set off the alarm. Try as I may I can't find where the fumes get in. Mind you these were near tropical storm force winds.
  5. Sjm9911
    10,618
    8,000
    And depending on where you are it could be from someone elses camper or generator.
  6. jmkay1
    6,964
    4,008
    I agree, cheap insurance. Also your propane detector may be too old to be beneficial. Much like carbon monoxide detectors they have a good till life.
  7. Anthony Hitchings
    3,051
    1,806
    Mar 2, 2019
    Oakland, California
    there is another long thread on this topic, in which I was repeatedly encouraged to get a combo fire-CO detector. Which I did.
  8. WrkrBee
    WrkrBee Un-Supported Member
    6,532
    3,447
    Detectors are for picking up the exhaust leak in a rusted out heat exchanger or a failed seal.
  9. Sjm9911
    10,618
    8,000
    Or from incomplete combition on anything else. Your stove, if not working right can put out a ton of CO. Same with anything that burns, ie water heater. Or the flue can get blocked by a nest. Its not always from just the exhaust.
  10. Mark60
    Mark60 Member
    68
    60
    Aug 23, 2020
    TN
    Where do you all mount them on the ceiling or lower on one of the cabinets which would be lower than the bunks.
  11. Sjm9911
    10,618
    8,000
    Depends on the detector you get. A smoke/co combo is on the ceiling or close to it. A co can be anywhere. A propane low to the ground, but up a bit. Propane/co is the same. Do not place directly in a corner or up on a wall. Thats dead space and stuff may not trigger the detector. At least in a house, not sure on the pup.
    BillyMc likes this.
  12. mowmow
    mowmow Member
    21
    30
    Sep 2, 2020
    We installed one. They don't cost much, and why take the risk? My hubby takes care of at least a handful of CO poisoning patients each winter. Usually doing stupid things trying to heat a house when utilities off, but sometimes it's a faulty furnace.
  13. theseus
    theseus Living the Darkside... Silver Supporting Member
    3,354
    808
    Feb 6, 2007
    Centerville, OH
    Propane detectors have a lifespan of approximately 10 years, though I have had them last longer. When the time comes, replace with a combo unit and you are good to go.
  14. Alifoxx03
    Alifoxx03 New Member
    Jun 13, 2021
    Having lost 5 friends in one camper to carbon monoxide poisoning at an event in 2011 I'd say the $20-30 investment in a detector is worth it. That was included in the first purchases to upgrade our 1996 Dutchman when we got it this spring.
    https://www.newschannel5.com/news/clarksville-victims-remembered-on-carbon-monoxide-awareness-day
    https://clarksvillenow.com/local/remembering-the-bwc5-on-carbon-monoxide-awareness-day/
  15. RhythmScience
    RhythmScience Member
    64
    32
    Jul 26, 2020
    Hagerstown, MD USA
    Regarding the placement of a ceiling-mounted smoke detector: we have one toward the back of the camper. We were packing up after a trip this summer and, just as we closed the last roof latch, we heard a beeping noise. I thought it was the LP detector picking up something, so we unlatched the roof and raised a bit and the beeping stopped. We lowered and latched the roof and the beeping was back. Took us a few minutes to realize that it was the smoke detector's 'test' button pressing on something I'd laid across the back bunk. I just have spread things out a bit to keep it from happening now. (Felt a bit silly taking so long to figure that out, though.)
  16. Sjm9911
    10,618
    8,000
    Unfortunately you dont have to go back far to see bad events unfold. It happens , not often, but happens every year. And like you said, totally preventable for 20 bucks.
    https://www.google.com/amp/s/people...per-faster-horses-festival-michigan/?amp=true
