Carefree winch problem
Discussion in 'Lift Systems' started by Mcameron1188, May 21, 2020 at 9:44 PM.
  1. Mcameron1188
    Mcameron1188 New Member
    May 20, 2018
    I have a 2005 rockwood freedom with the carefree winch. When try to go up or down all I get is a clicking noise and no movement from the winch. The battery is good. Sounds like the clicking noise may be coming from the relay? And ideas? Thanks!
  2. WrkrBee
    WrkrBee Well-Known Member
    3,125
    1,298
    Welcome to the Portal from South Carolina. See if you have ants in the control box. I've had them shutdown 2 irrigation relays, a 110v switch, and a 220v switch at the same time.
