Cellphone antenna
Discussion in 'Campsite Electronics' started by Hearty Sarsoza, Oct 30, 2019.
  1. Hearty Sarsoza
    Hearty Sarsoza Member
    92
    21
    Apr 5, 2019
    What do you guys use for cellphone antenna? I have the weboost 3g amplifier but the small antenna that comes with it yields very minimal gain.
  2. bearman512
    bearman512 Well-Known Member
    1,229
    78
    Apr 17, 2010
    Albuquerque NM
    Just stating it yields minimal boost doesn't tell us anything. Many things can cause poor gain IE how good is the reception before boosting. Are you in a heavily forested area, mountainous terrain, how high is the antenna mounted, I have the weBoost Drive 4G-X RV and at 15' high with only 1 bar showing on the phone I get great boost to 3 bars when I turn it on. This is 4g, 3g is even better.
    Hearty Sarsoza likes this.
  3. Hearty Sarsoza
    92
    21
    Apr 5, 2019
    Did you use the small magnetic antenna that came with it or you used another type of antenna? Thanks for the reply. It did gave me about 1 bar extra signal with the small magnetic antenna
  4. bearman512
    1,229
    78
    Apr 17, 2010
    Albuquerque NM
    I us a 18' pool cleaner pole $25 will get you another 2+ bars. You also need to know where the cell tower is as you have a directional antenna that needs to be adjusted for maximum reception.
    HappyTraveler and Hearty Sarsoza like this.
  5. Hearty Sarsoza
    92
    21
    Apr 5, 2019
    Thanks for the info bud
  6. joet
    5,015
    1,081
    I use a yagi antenna. it was supposed to have 6bd gain. You need to know where the tower is as this antenna is a directional
    beam
  7. WVhillbilly
    WVhillbilly Well-Known Member
    841
    638
    Jun 6, 2018
    WV
    The only time I've seen these work right were when they were mounted on a long pole, usually PVC pipe.
    We've had jobs in areas of poor cell coverage and have tried these several times, usually with poor results.
    If you NEED to have phone service buy or rent a sat phone.
  8. Hearty Sarsoza
    92
    21
    Apr 5, 2019
  9. Arruba
    Arruba Well-Known Member Gold Supporting Member
    705
    371
    Nov 28, 2014
    Central Oregon
    In my work vehicle I have a Wilson booster with standard rooftop antenna. If I’m getting 1-2 bars but won’t hook up the booster gets 3-4 bars, solid 1 bar goes 2 maybe 3, and in&out 1 will net 2. So about 1 level up with the booster. Sometimes it will pull something out of nowhere, but sometimes not.
    The Yagi mentioned above works well. We use them with the FTS, (Field Telephone System) units on our remote sensing stations. As mentioned about others, it also needs to be up in the air for best results.
    Good luck
  10. Hearty Sarsoza
    92
    21
    Apr 5, 2019
    Thanks very much for the info.
  11. GrueMaster
    GrueMaster Active Member
    196
    76
    May 22, 2013
    Saint Helens, Oregon
    My friend (AT&T) tried getting a signal while we were camping. He took an old cell phone, enabled tethering on it, and sent it up ~200' on a quad drone copter, while monitoring the signal on his other phone. When the drone reached an elevation that it could get a signal, he got a ping on Facebook regarding a new post on his timeline. When he looked, it was a picture of him launching his drone to get signal, that I had posted 2 minutes earlier (Verizon).
    To answer your question, they make signal boost antennas, but you won't find them at any cell phone store. You need to go to a ham radio store. They should have something, or at least point you in the right direction.
  12. tenttrailer
    3,745
    645
    Jul 18, 2013
    Thornville, OH
    I have a 18 db wifi attends that I attach to a window laptop and create a hotspot. But it's only good in CG that have some weak wifi.
    The brand is a Bear something with a USB cable to the laptop.
    I have thought about looking into the cell phone personal towers that the cell phone companies sell????
  13. WVhillbilly
    841
    638
    Jun 6, 2018
    WV
    Are you looking for a phone to use for data, emergencies, or does your workplace require you to stay in contact?
    These work very well for emergency use and sending/receiving texts. https://explore.garmin.com/en-US/inreach/
    I usually seek out places with no cell coverage for camping, but that's just me.
  14. Anthony Hitchings
    3,148
    1,871
    Mar 2, 2019
    Oakland, California
    I just bought the InReach Mini - great little gadget for life safety, might be a little $ for simply "staying in touch" though it will do that - easier when paired to a cell phone.
  15. WVhillbilly
    841
    638
    Jun 6, 2018
    WV
    I have used a Spot tracker for years on my motorcycle.
    Most of the places where I ride don't have cell service, and it's nice to be able to hit the check in button and let everyone know I'm not bear food.
