Changing a pup tire
Discussion in 'Tires / Brakes / Bearings / Axles' started by BlackTalon, Jul 7, 2007.
  1. BlackTalon
    BlackTalon New Member
    39
    Mar 14, 2007
    I have a palomino mustang and while reading the OM about changing a tire ,there isn't any mention of where to position the jack to lift the pup. I figured to ask so I don't twist the frame. I have an old scissor jack that I was going to put onboard, will that work?
  2. dirtracin
    dirtracin New Member
    Apr 30, 2007
    From what I have read never put the jack on the axle, always use the frame to lift up the pup
  3. Fly
    Fly New Member
    130
    Jan 14, 2007
    A good place to position the jack (and as far as I know the recommended place by most trailer manufacturer's), on single axle trailers anyway, is right behind the tire, on the main frame.
    Fly
    '99 Starcraft 1706
    '02 GMC Sierra
  4. witzend
    witzend New Member
    19
    Mar 20, 2006
    My manual says to lower the tongue jack all the way, put the rear stabilizer all the way down on the side of the trailer with the flat, and then raise the tongue jack until the tire comes off the ground. I think when using a garage jack, or scissor jack, though, the frame rail would be the better choice. The axle (at least on my trailer) doesn't look hefty enough.
    Jim - WitzEnd - Tacoma <img src=../Images/flags/us-Washington.gif border=0 align=middle> <img src=../Images/flags/us.gif border=0 align=middle>
    '86 Coleman Sequoia <img src=../Images/icons/icon_smile_pu.gif border=0 align=middle>_<img src=../Images/icons/icon_smile_suv.gif border=0 align=middle> '98 Chevy Astro
