Changing tires on 95 Starcraft
Discussion in 'Tires / Brakes / Bearings / Axles' started by G T, Oct 6, 2019.
  1. G T
    G T Member
    75
    Aug 19, 2019
    Florida Panhandle
    Ok, fellow pup owners. Here's my dilemma... the manual for my popup says to place the jack under the axle plate. sounds good but when I went to do that realized the previous owner had the axle turned to raise the camper height. the plate is now on top of the axle. Soooooo do I place my floor jack as close to the wheel where the plate is or do I use the frame member closest to the tire? I don't remember ever changing a tire in my life so this will be a new thing for this ol' gal...
  2. FARfetched
    FARfetched Active Member
    446
    186
    Nov 22, 2018
    Sector 706, Planet Georgia
    Jack up the axle directly?
  3. joet
    4,761
    960
    Place the jack under the axle at the u bolts
  4. 1380ken
    1380ken Well-Known Member
    2,096
    530
    Nov 7, 2013
    Mass
    Either is fine
  5. G T
    G T Member
    75
    Aug 19, 2019
    Florida Panhandle
    According to the manual it says "when raising the trailer use a scissor or hydraulic type jack on a wood block directly under the axle beam." So I guess I misunderstood that the plate was necessary...
  6. G T
    G T Member
    75
    Aug 19, 2019
    Florida Panhandle
    Yes! That's exactly what I did and it worked like a charm. Tires changed and we are done with that chore. Now on with the next one! LOL... never ending.
