Checking unused brakes
Discussion in 'Tires / Brakes / Bearings / Axles' started by Campgrandma, Feb 27, 2021.
  1. Campgrandma
    Campgrandma Member
    75
    30
    Feb 4, 2021
    Cibolo, TX
    Pretty sure the previous owner never use the electric brakes on my 2004 Jayco Eagle select. What things do I need to do to check the brake system to make sure it’s fully functional before utilizing the brakes?
  2. xxxapache
    4,119
    2,430
    The first thing I would do is hitch up and pull it around the block to see of the brakes work. After that, I would probably pull the drums and look for rust, put anti seize on the adjusters and any pivot points, put the drums back on and adjust the shoes.
  3. Fish N Farm
    Fish N Farm Well-Known Member
    586
    460
    Aug 4, 2020
    Pearland Tx
    I would ask who ever does your auto repair and ask them if the work on electric brakes. If not find somebody that does. A place that works on AG trailers probably works on them. Not saying you can't check them yourself they are really simple. Look at some U-tube stuff. If you take the hubs off and decide to have some else do the repair you can't just slap the hub back on and tow it somewhere.
  4. Campgrandma
    Campgrandma Member
    75
    30
    Feb 4, 2021
    Cibolo, TX
    Thanks! Finding out there is a lot of overdue maintainance on this pup!
  5. Anthony Hitchings
    3,168
    1,883
    Mar 2, 2019
    Oakland, California
    the annoying thing with ebrakes is that you hav to remove the entire hub to access the brake parts. Unlike a car, where the hub stays in place.
  6. jeepster04
    jeepster04 Active Member
    252
    162
    Nov 23, 2010
    Not much else to add other than I agree with checking to see if they work, then take it all apart and see if they have a bunch of rust built up inside the drum. Good time to clean/repack the bearings also.
  7. tombiasi
    6,673
    2,239
    What will be gained by seeing if they work? The drums are going to be pulled anyway.
    Anthony Hitchings likes this.
  8. xxxapache
    4,119
    2,430
    Satisfying my curiosity would be gained. I would go into the drum pulling job knowing I had working brakes.
  9. tombiasi
    6,673
    2,239
    Would that knowledge influence what you did to the brakes?
  10. xxxapache
    4,119
    2,430
    Probably not. However, if I did the brake work before testing them and later found them not working, I'd be second guessing what I did, because I wouldn't have knowledge whether they were working or not to begin with.
    My TT was used. It had good working brakes when I bought it. Shortly after pulling it home, I still pulled the drums to look at the pads and magnets , as well as the inside of the drums. I brushed off the dust, greased the adjusters and pivot points. Then I put the wheels back on and adjusted the shoes....Did it need any of it? Probably not.
  11. tombiasi
    6,673
    2,239
    If it makes you feel better by all means do it. I would be planning a complete brake job, back plate magnets, shoes, and trace the wiring. I'd wait to see the hubs before I bought new hubs. If the brakes didn't work after that it would be my fault.
  12. jmkay1
    7,058
    4,116
    I agree with getting them checked prior to driving any long distance with them. I bought my popup and saw a recent inspection sticker so assumed someone did the work of inspecting the camper as per required in our state so figured everything was working and legal. Turns out while hauling the camper home 5 hours my breaks froze and essentially glued itself. Never having towed a camper with breaks I had no idea what was normal and the windows were up so didn’t get any strange smells. It was only putting my chalks in is when I discovered my hubs were hot as fire. So to say I hooked back up and drove it to the shop. Turns out my entire drum essembly were rust buckets and rust was preventing normal operation of the breaks. $600 later I got two new drum essembly and new barrings as they looked worn as well. Good luck.
