Checklist
Discussion in 'General Camping Discussion Forum' started by Greg James, Jun 21, 2020.
  1. Greg James
    Greg James New Member
    Jun 21, 2020
    Does anyone have check lists for camping (Pre and Post) and winterizing?
    I'm a military man and checklists makes sure I didn't forget anything.
    Thank you for your time.
    Rik Peery likes this.
  2. Camper054
    Camper054 Active Member
    306
    147
    Jul 23, 2019
    Indiana
  3. WrkrBee
    WrkrBee Un-Supported Member Silver Supporting Member
    5,988
    3,106
    I would make my own checklist. Working on one now for the new to us travel trailer. There's about 20 steps just to connect to tow vehicle and set the weight distribution hitch. It will evolve over time, and will change with each trip.
  4. jmkay1
    6,649
    3,598
    I made my own check lists as I found every manufacturer has their own way to set up and every manufacturer has their own location for the pump, water heater etc for winterizing. I studied my manual For set up procedures, YouTube came in handy for winterizing as my manual was seriously lacking there. Also helped to run through the steps yourself and make notes. Every camper has a different set of options so Some may not even have to worry about winterizing where as others with more options do. My old Jayco only had a sink with city water connection nothing else. I didn’t even have to worry about winterizing that popup. Now my Fleetwood is much more involved and many more steps to worry about.
    mdrsteve, Greg James and Tom Jordan like this.
  5. DigitalGuru
    DigitalGuru Active Member
    543
    38
    Jul 5, 2011
    Michigan
    Here is the checklist we use for our popup.
    Pop-Up Setup
    1. Check site for setup location. Check for issues; power, water, flatness, drainage, etc.
    2. Back in and check left/right level. Place chocks in front and behind the high side tire.
    3. Unhitch and move tow vehicle away then level front to back roughly.
    4. Place BAL leveler under low side tire and level.
    5. Check front to back level again and adjust if needed.
    6. Open storage, grab cranks and bed poles.
    7. Unzip storage bag on the awning. Leave straps tied until later.
    8. Unlatch and raise the roof 6in, attach gizmos, raise roof completely.
    9. Put the stabilizers down snugly. Do not raise the camper more than ½”.
    10. Install bunk supports, pull bunk ends out, pull dinette out.
    11. Lower step.
    12. Install door.
    13. Install Shepherd poles into each bunk end.
    14. Swing sink up into position.
    15. Check stove knobs and turn on propane tanks.
    16. Plug shore-line cord into power box.
    17. Attach Velcro and bungee cords.
    18. Open Drains.
    19. Plug AC cord in and turn on (if necessary).
    20. Make sure frig is set to proper setting and is on.
    21. Pull all gear out to bunk area.
    22. Setup interior table.
    23. Setup awning.
    24. Place carpet and stake down.
    25. Setup exterior tables and place stoves.
    26. Light hot water heater.
    27. Setup exterior chairs and drink cold beer until well rested and beer is finished.
    28. Unpack all the crap you brought to eat and wear, make beds.
    29. Drink another beer while grinning about the fact you’re now camping and didn’t break anything.
    Pop-Up Tear Down
    1. Pack all interior stuff and pull bedding off.
    2. Pack bedding, coffee maker, etc., in dinette benches.
    3. Pack dinette table. Pack toilet / shower.
    4. Turn off water pump. Drain faucets and cover water dispenser.
    5. Drop sink into cabinet.
    6. Close roof vent.
    7. Make sure fridge is set to proper setting.
    8. Unplug air conditioning plug and place wire on bed.
    9. Pack into interior floors.
    10. Drop shepherd poles.
    11. Pack door.
    12. Pack exterior stoves, grills, and tables.
    13. Extinguish hot water heater.
    14. Turn off propane tanks.
    15. Unplug shore power and stow cables and adapters.
    16. Uncover poles / detach Velcro and bungee cords.
    17. Close drains.
    18. Push dinette in. Pull fabric out.
    19. Push bunk ends in.
    20. Raise step. Close outside door.
    21. Raise stabilizers.
    22. Lower awning poles.
    23. Lower roof. Pack support poles.
    24. Pack awning.
    25. Latch all corners.
    26. Lower BAL leveler.
    27. Hitch tow vehicle, remove chocks, move off blocks.
    28. Store chocks & wood blocks.
    29. Open H20 tanks, low point caps.
    30. Lock latches, trailer tongue and clam-shell.
    31. Clean up campsite. Take trash to dumpster.
    Efayen and OneGoodEye like this.
  6. OneGoodEye
    OneGoodEye New Member
    Jul 22, 2020
    West Kootenays, British Columbia, Canada
    What is a BAL leveler? I'm going to google it too, is it a good investment for a newbie?
  7. Rik Peery
    Rik Peery Well-Known Member Gold Supporting Member
    1,447
    1,833
    Jun 15, 2018
    Virginia
    Welcome dude, good to see some vets showing up...pop up is a MAJOR step up from a poncho hooch lol; tons of info & good people at your disposal [CB]
  8. campfire Joe
    campfire Joe Active Member
    282
    172
    Jan 27, 2015
    peru new york
    For winterizing my camper i refer to the owners manual that came with it. I also note in the manual what i did and the date. Each year i pretty much follow the same steps. Also put in there things i have changed out like the tires/battery/ CO detector.
  9. DigitalGuru
    543
    38
    Jul 5, 2011
    Michigan
  10. 4xMeteor
    4xMeteor Well-Known Member
    784
    285
    Jul 30, 2012
    Georgia
    I never used checklists, but I've evolved (gotten older), and now I create a grocery checklist from the menu to make sure I buy/pack everything for cooking.
  11. Greg James
    Jun 21, 2020
    The pop up didnt come with an owners manual.
  12. Camper054
    306
    147
    Jul 23, 2019
    Indiana
    @OneGoodEye , here is a picture of the BAL leveler I used at my last camping. I was lucky to get this at a faction of the retail price from a local CraigList seller who upgraded his camper and didn't need it anymore. It is a bit bulky and heavy, but worth having for the ease of use.
    OneGoodEye likes this.
