Chocking your pup
Discussion in 'Stabilizing Your Camper' started by scootit, Jun 4, 2016.
  1. scootit
    scootit Member
    45
    Feb 16, 2016
    I use the BAL on one side of the pup.What do you use on the other side to keep it from moving? :)
  2. speckhunter80
    4,782
    62
    Jul 26, 2012
    Shell Rock Landing, Hubert NC
    Rubber chocks bought at Harbor Freight
  3. shuang2
    shuang2 Well-Known Member
    1,185
    93
    Apr 20, 2010
    At home - a rock. At campsite- rocks or 2X4 piece of wood block.
  4. Snow
    10,183
    1,089
    Wood chocks made from a piece of cedar 4x4 post..
  5. mpotapa
    mpotapa Member
    510
    Mar 11, 2014
    I bought this to use on the other side of my bal leveler. http://www.amazon.com/gp/aw/d/B001UGPEJA/ref=mp_s_a_1_6?qid=1465038693&sr=8-6&pi=AC_SX236_SY340_QL65&keywords=bal+wheel+chocks&dpPl=1&dpID=31drsLtdmgL&ref=plSrch
  6. sleach
    683
    148
    May 17, 2014
    Boulder, Colorado
    Two pieces of firewood. Have been using the same pieces for years. This is the second set, as I left the first set behind during a hurried pack up and bailout due to approaching snow storm. Second set has been spray painted bright red.........
  7. 94-D2
    94-D2 Happy Campin'
    2,279
    134
    May 21, 2010
    Sutter Creek CA
    I am partial to a braking chalk. It helps restrict shimmy when in the pup. I used to put pressure on the chalks with the tv then have DW block them before dropping the trailer. That also helped with the pup shimmy.
  8. owenpsmith
    owenpsmith New Member
    18
    May 27, 2014
    2x4s, front and back behind each wheel. However I found that the trailer was much less wiggly when the chocks are tight. So now I get the trailer positioned, put chocks in front and behind, then pull forward an inch or two, then get the DW to kick the reach chocks in further. Makes them nice and snug.
  9. Sneezer
    1,546
    542
    I use rubber chocks from Harbor Freight. However - I plan to pick up a BAL tire chock to help further reduce some of the bounce I still have when set up.
  10. Dubbya
    6,130
    53
    Aug 2, 2011
    Steinbach, MB
    I use plastic chocks in front of and behind the tire.
    When I've got the camper where I want it on the site, I put a chock behind the tire, back the camper into it, put the other chock in front of the tire and put the truck in neutral. Then I put the BAL on the low side tire, unhitch and level the camper.
    The camper hardly moves even if when I practice my squaredancing routine. [8D]
  11. silvermickey2002
    4,676
    477
    Sep 11, 2008
    Morris County, NJ
    We use the plastic chocks on both sides. I get them in pretty tight and don't have any movement issues.
