City Water Leaking - 1993 Starcraft Galaxy 1224
Discussion in 'First Time & New Camper Owners' started by TBrum, Jun 11, 2020.
  1. TBrum
    TBrum New Member
    May 31, 2020
    Hello,
    Another noob question. Getting ready to head out in a couple weeks and was testing the city water hookup on my new pop up. Everything seems to work just fine, except for one problem. Where the hose and city water intake meet, there is a constant stream of water coming out. Not sure how to remedy that other than teflon tape or something like that. The fittings don't appear to be bent or anything. Also tried multiple hoses to the same effect. Any advice?
    ~Tim
    (1993 Starcraft Galaxy 1224)
  2. Sjm9911
    8,378
    5,733
    Did you use a water pressure reducer? If not you may have blow the pipe apart. If its just the hose maybe the inlet needs replacing( thats if your hose washers are good). Should be 4 screws and it will pull off the camper.
  3. eoleson1
    eoleson1 Well-Known Member Gold Supporting Member
    3,237
    1,382
    Jul 5, 2011
    Macomb County Michigan
    The camper side fitting should have a rubber hose gasket in it. Same gasket that a garden hose uses. I would start with that.
    Raycfe and 1380ken like this.
  4. Old_Geezer
    Old_Geezer Well-Known Member
    2,639
    358
    Sep 29, 2009
    Southwest PA
    And they're notorius for the body splitting when folks use a winterizing kit on the pump, and do not push in the check valve letting the anti freeze back flush out to and through the connection. You usually can not see the crack until its removed and the supply line is pulled loose. I've seen them leak like the OP describes outside when that happens, and sometimes they leak inside.
  5. TBrum
    TBrum New Member
    May 31, 2020
    Thanks all. Only needed a hose gasket on the intake.
  6. BillyMc
    BillyMc Well-Known Member
    1,922
    1,256
    Mar 25, 2018
    Get a pack of these, they stop sealing from time to time. With time you'll get an idea of spare little things to keep on hand. Spare fuses, replacement bulbs, test light, and electrical tape are a few other things to keep on hand.
  7. Snow
    11,158
    1,818
    They are notorious for leaking when people do the above and push that check valve while under pump pressure... oring tells over and causes a leak..
