Clear tube on water pump
Discussion in 'Plumbing Systems (The Fresh, The Blue, The Grey, &' started by JMSubRN, Jun 12, 2015.
  1. JMSubRN
    JMSubRN New Member
    151
    Apr 15, 2015
    I was unsure whether to post this here or in the mystery parts section. But here goes.
    There is this clear tube coming off of the top of my water pump. The other end is open. What is this? Will water come out and leak into the floor?
  2. HLFAHEMI
    HLFAHEMI New Member
    Jul 18, 2014
    That my friend is a tube for running plumbing antifreeze through your water system when you put the trailer away in the fall.
    As long as the valve the tube comes out of is turned in the direction you have it in now no water should come out of it.
  3. E3 Junkie
    E3 Junkie Greetings from Granada Hills, CA.
    314
    Sep 22, 2012
    I have no idea.
  4. tcanthonyii
    tcanthonyii Member
    910
    Jun 29, 2010
    Yup I'm thinking antifreeze.
  5. kitphantom
    11,757
    854
    Antifreeze tubing.
  6. JMSubRN
    JMSubRN New Member
    151
    Apr 15, 2015
    Thank you, friends!
  7. Customer
    Customer Well-Known Member
    2,436
    243
    Jun 5, 2014
    Like said, winterizing suction tube.
    If the valve is closed everything will work fine. If the valve is open it will suck air or any liquid you stick the hose into.
  8. sleach
    683
    147
    May 17, 2014
    Boulder, Colorado
    Amen brothers and sisters, it is most surely an antifreeze suction tube.
    JMSubRN, you are fortunate to have this permanently installed tube and associated valving. When we got our Arrowhead it came with hardware to allow disconnecting the tank-to-pump line and substitute an antifreeze line. A nuisance task, with spilled water every time. Switched to a permanent line after the second winterizing section.
    Be sure to read and heed the winterizing section in your owners manaul, and check out the winyterizing tips on this site. You'll be glad you did.
  9. tfischer
    tfischer Well-Known Member
    3,528
    1,031
    May 21, 2014
    Yep, I installed something like that last year for winterization. Works great.
