Clear vinyl window damage. User error?
Discussion in 'First Time & New Camper Owners' started by Jhunt012, Nov 21, 2015.
  1. Jhunt012
    Jhunt012 Member
    53
    Aug 27, 2015
    I have a small tear/crack in one of my clear vinyl windows. It is basically where the window was creased when the camper was closed up. I have the clear windows zipped up when I close up the camper. Is this the proper way to do it? When I open it up there are several creases in the clear vinyl and I'm worried it will all lead to cracking. Anybody else experienced this? Any ideas for an effective patch? Thanks for your time!
  2. Heartman_wa
    Heartman_wa Active Member
    1,703
    Mar 5, 2006
    Tacoma WA.
    We close up with the window zipped closed with no problem. Maybe someone was using windex to clean the window that will make them brittle.
  3. threebeachboys
    threebeachboys Active Member
    398
    28
    Jul 18, 2005
    We had a about a quarter-sized hole in one of our windows. Went to the dollar store, bought clear contact paper and patched on each side. Held for several years and was still fine when we sold the camper. Though not sure why yours would have cracked/torn to begin with . . . . We always closed our pop-ups with the windows zipped shut.
  4. moon
    moon New Member
    28
    Aug 6, 2015
    Tujunga, CA
  5. HiFiDave
    HiFiDave Singin round the campfire
    1,069
    Feb 1, 2012
  6. PointyCamper
    PointyCamper Active Member
    591
    161
    Nov 25, 2015
  7. Nandy
    Nandy Active Member
    2,255
    Mar 29, 2010
    Cracked plastic windows are sometimes caused by closing/setup during extreme cold weather. When in extreme cold weather running a heater (you wont be able to run your furnace while the camper is folded) for 10 or 15 min will get the plastic soft. When closing the camper do the same. I worked in my camper this week and still with 40's weather the vinyl canvas was hard to the touch. I used my heater to get it soft again when I closed it this evening.
