coldest temp to open the pup
Discussion in 'Camper Storage / Winterizing & De-Winterizing' started by Fred1diver, Mar 29, 2019.
  1. Fred1diver
    Fred1diver Active Member
    214
    110
    Sep 11, 2018
    hey everyone, got the itch to open may pup to get her ready for the season, what are the coldest recommended temps to open them up, in other words, how cold is to cold for a pup, I just don't want to break anything
  2. arge
    arge Member
    78
    27
    Feb 27, 2018
    >32f should be very safe, but I guess something in low tens should be ok too.
    The windows are prone to breakage in negative temperatures (Fahrenheit)
  3. Natureangel
    1,069
    236
    Feb 28, 2016
    Illinois
    Just to be cautious, I wait for 40+F.
  4. BikeNFish
    BikeNFish Well-Known Member
    3,336
    2,247
    Apr 24, 2017
    Maplewood, MN
    I've heard rumors that you could crack the plastic windows if you open or close the pup if it is too cold, but I have never actually seen a post from someone that it actually happened to.
  5. Jwwiff
    Jwwiff Member
    34
    17
    Jul 16, 2015
    Took my Bayside out of hibernation last weekend and have been working on it this week. We put it down tonight - around 40F - worked on getting the top down all the way as the canvas was more stiff than when it was warmer. No issues with the windows. I’m on the SW side of the twin cities so not all that far from you .
  6. bols2Dawall
    bols2Dawall S.W. Ontario
    1,472
    164
    May 19, 2010
    Lasalle Ontario
    I've put a ceramic heater inside the closed camper for a couple of hours to warm the inside before opening and closing
  7. Bonecrusher
    Bonecrusher Active Member
    100
    34
    May 5, 2018
    I didnt realize there was a temperature worry... I went camping with my popup in 23 degree weather with no ill effect..
  8. kitphantom
    12,050
    1,098
    IIRC, the suggested limit for the replacement vinyl canvas on our first pup was somewhere around 0*F. We had it camping with lows in the teens, folding it down when it was still in the 20s. It took a bit of patience, since it wasn't the most malleable at that temp, and sunshine on the canvas helped.
    I don't remember a stated low for the second one, which had Sunbrella canvas, but still had vinyl windows. We also had that one out in the teens, but at least the canvas portion folded easier when cold than the first pup.
  9. brwarrior
    brwarrior Active Member
    178
    81
    Mar 26, 2017
    Clovis, CA
    Owners manual for my 2015 Flagstaff says the plastic windows have a -20F cold crack with a minimum recommended temperature of 0F.
  10. Sjm9911
    5,870
    3,338
    The problem is as the material ages it gets brittler. So recommendations are good, but just that recommendations. It also heats up in the sun and becomes softer and can stretch more. ( when i did awnings, we put up the patios in the afternoon, more sun, and you had to let the fabric heat up before doing a final stretch and tie down) The biggest concerns would be that it can catch and crack more easily in extream cold the older it gets.
  11. CamperChrissy
    CamperChrissy Well-Known Member
    634
    337
    Nov 25, 2016
    Chicago suburbs
    Today I popped mine up, 47 degrees and cloudy. No issues!
  12. Fred1diver
    214
    110
    Sep 11, 2018
    ok cool, that means I can open mine on saturday, it's supposed to go up to 11°c, almost 52°f, can't wait to get her ready for the season
    kitphantom likes this.
  13. Halford
    Halford Well-Known Member
    3,563
    566
    Sep 28, 2011
    Santa Clarita, California
    Mine did in 27 degrees. damaged some of the vinyl rubber in some places.
  14. Halford
    3,563
    566
    Sep 28, 2011
    Any temp above 40 would be best. Depending on the new technology, some could be opened below freezing point but up to a certain degree.
  15. BikeNFish
    3,336
    2,247
    Apr 24, 2017
    Maplewood, MN
    So, there ya go! The answer to the question, "Can you damage your pup if you open it when it's cold?", is "Yes!"
    I would also think that it is harder on the lift system when the grease and oil and the lift system in general gets stiffer in cold weather. I know that when riding my bike, the bike itself feels a lot different, a lot stiffer, when the temperature drops below 50*F. The same has to be true with a pup.
    bols2Dawall likes this.
  16. Halford
    3,563
    566
    Sep 28, 2011
    Not necessarily damage popup, just the fabric without the new technology. It may be harder to lift the roof but not necessarily damaging it.
  17. BikeNFish
    3,336
    2,247
    Apr 24, 2017
    Maplewood, MN
    I agree with your statement. However, "You can" does not mean "you will".
    There are many variables that go into damaging a pup in cold weather. Example - My indoor stored 2014 pup will have a different reaction in the cold than a 1995 Viking that has been left outside for 24 years. I would trust opening by pup at 30 degrees F before I trust a weathered Viking at 30 degrees F.
