Coleman ABS Roof
Discussion in 'Roof/Floor Repair & Maintenance' started by benfrench, Oct 11, 2011.
Have you had any issues with your Coleman ABS Roof?
  1. Yes, sagging, I fixed it ..
    14.8%
  2. Yes, sagging, I got rid of it ..
    4.3%
  3. No, never had any issues ..
    32.2%
  4. Yes, cracking, I fixed it ..
    51.0%
  5. Yes, cracking, I got rid of it ..
    11.4%
  1. Rick245
    Rick245 New Member
    Jun 28, 2019
    Michigan
    I can see why you would need to drill some "access holes" to inject the epoxy. I did have one area where I wasn't sure I could get the epoxy far enough in and considered drilling a hole. I actually used a razor knife to "score" the ABS and open up a sort of flab to get the epoxy under the ABS. Any cracks that are wider than a "hairline crack" I use the ABS/M.E.K. mixture to fill. It has worked out very well so far. If you do drill holes I would simply keep them to a minimum...….the G-Flex will flow very nicely before it begins to set. I believe it has a "working time" of over an hour. Use a roller or simply press down on the entire area that has delaminated to get a good bond. Then put down some weights of heavy object to keep the ABS in contact with the substrate till it has set. Give it time to set.....don't be in a rush. After it has cured, either use the G-Flex or the ABS/MEK mixture to fill the drill holes. Sand smooth. Seal with a coat of Grizzly Grip or a good quality truck-bed-liner -----I'm using U-Pol's Raptor. It is a spray on liner that covers well and looks good. Keep me posted on your progress.
  2. CoolCanuck
    CoolCanuck Member
    67
    25
    Oct 30, 2016
    Okanagan Valley, BC, Canada
    I've just filled some of the cracks near the roof seal edges with the ABS/MEK slurry. The seal was replaced by the previous owner and is still good. Though I do have new ones for the roof / box just in case. Planning on doing the roof delam's when/if it gets worse. Will use vacuum bag technique. No sense doing it when there's no real need yet.
  3. Rick245
    Rick245 New Member
    Jun 28, 2019
    Michigan
    The vacuum technique should work great. I have only used vacuum clamping with smaller woodworking projects. Would love to see how it works on a larger area. The trick, I suspect, is getting a good, positive seal. Once I get my bedliner sprayed on I will post some pics.
  4. Bultacobill
    Bultacobill New Member
    Jan 14, 2020
    So I am new to the site and my problem brings me here. My 2000 Coleman Westlake is suffering from the cracks and delamination. Of course when I bought it 7 months ago it only had a few and now it has a few hundred little cracks and two huge ones that have caused an area about 4 foot by 6 foot to delaminates. I have ground out each crack and glued the delamination which doesn’t seem to hold well.
    To get to my point I have read this whole thread and see that most folks that go the MEK and grizzly grip route are not completely happy. Most folks that just remove the whole ABS roof and cover the remaining fiberglass with Grizzly grip are happy. Is this true? Do you folks that have removed the ABS have any regrets? I do Auto body work so I am comfortable doing either but I don’t want to throw good money away to fix the ABS plastic only to have to remove it and start over. Thanks in advance to your reply.
  5. ezakoske
    ezakoske Active Member
    542
    85
    Nov 30, 2014
    Escondido, CA
    I think that once the cracking and delamination starts, the MEK/ABS slurry is just delaying the inevitable....I tried that for a while, and then stripped off the ABS and rolled on the Grizzly Grip. No regrets.
  6. Sjm9911
    5,312
    2,903
    My abs slurry mix didn't last. And im pretty through with fixing stuff. Others say it lasted. I wouldn't spend the time on fixing it if i had to do it again. I would strip the abs. I will say i sold the pop up before i tryed it. Some i think removed the abs and fiberglassed the lid. The westlake is a nice camper, same as i had and the same year. If in good shape inside its worth fixing it up!
  7. Bultacobill
    Jan 14, 2020
    Thanks for your reply’s. My next question is can I just remove the center part of the ABS to the outside horizontal edge so as not to interfere with the awning rail and the roof support covers? If so will the grizzly grip by using a few coats fill in the area between what’s left of the ABS on the sides and the fiberglass? If this isn’t possible and the entire ABS is to be removed how do I reattach the awning rail?
  8. GreyFox
    GreyFox Well-Known Member
    1,804
    897
    Oct 10, 2018
    S Ontario
    The bigger question is how you would separate the plastic awning rail (Part #4753-1211) from the ABS without destroying the rail. [?:~{] It was originally affixed to the ABS roof with a specific adhesive (Fleetwood part #4716-2171) which of course is now no longer available. :( JMO but I think I'd ditch the awning entirely and instead use a stand alone canopy like a First Up. [A]
  9. Bultacobill
    Jan 14, 2020
    I’ve decided to cut just the center section out and leave the edges since they have not delaminated or cracked. This way I can retain the awning track. 8CD14521-3370-47BD-9CE4-5FAC97707957.jpeg
  10. Sjm9911
    5,312
    2,903
    You could buy a new track and bolt it through using backing plates. But it seems your off and running allready.
  11. Bultacobill
    Jan 14, 2020
    7378CACC-A7A2-4813-B15B-D33AB4290B9B.jpeg CE201E6B-C3EA-41FC-B612-4CA51E30A705.jpeg D3EE3836-F2D2-42A1-966F-09406F16F965.jpeg I finished the roof this weekend with Grizzly Grip. I used one “kit” plus an extra gallon on my 2000 Coleman Westlake. I have about two quarts left that I am going to use on the storage compartment lid. I have to say as you roll the Grizzly Grip on it looks terrible but as it drys and sets up and looks real nice with a little texture to it. I did leave the ABS on it just around the edges so I could save the awning track like I showed in my previous post. It did have some cracks and delamination which I did repair. The MEK slurry I used after filling in the cracks also cracked. I did coat over them so time will tell how they hold up. The cracks in the Slurry mix where extremely small. I put extra Grizzly grip in those spots. Time will tell how it holds up. I’m going to wait 2 weeks until I put the new seal and awning back on so the GG can completely cure.
    Orchid and Sjm9911 like this.
  12. CoolCanuck
    CoolCanuck Member
    67
    25
    Oct 30, 2016
    Bultacobill - So what was directly under the exterior ABS? Was there anything between the foam and ABS? From what I can tell from mine, where I reglued small sections of the ABS to the foam, it appears to be hardened "skinned" foam.
    What did the inside ABS side (towards the foam) look like? Did it have a "matching structure"?
  13. Bultacobill
    Jan 14, 2020
    Once I removed the outer ABS the interior was a hardened foam with sort of a fiberglass fiber on it. The surface was smooth so the Grizzly grip went on easy. Here is a picture before the Grizzly grip and a new photo with the new seal installed. EF981722-B1C2-4D7F-9D86-3AE930C53C43.jpeg C882B029-AD38-41E6-93D2-CD357B639BAC.jpeg
  14. Sjm9911
    5,312
    2,903
    Looks like fiberglass to me. Thats what was under mine also. The weird uniform texture is why i think it is fiberglass. I dont think a hardened foam would get that uniform look. But as i said in other threads they did have 2 manufactures. So they might have been diffrently made, or maybe based on the year changed the process. I can only speculate. Oh if you have any gg left over ( just an idea) i made a new plywood shelf for the exterior stove. I left mine out in the rain. The old pressboard from 2000 sucked the water up like a sponge and it disintagrated. The gg held up well for a coating on the plywood for the stove. Mite as well use it all up as it has an experation date.
  15. EmilyW
    EmilyW New Member
    Jan 12, 2020
    Knoxville
    We are looking to purchase one in very similar condition. How has your methods held up? Ours would need a bit more structural support, and is much like the pics you posted.
  16. Bultacobill
    Jan 14, 2020
    That’s a great idea! I have the same thing happen with my stove. I have a quart of GG left and haven’t figured out what to do with it. Thanks.
  17. Bultacobill
    Jan 14, 2020
    Ok, so this isn’t the “just fixed my outside stove with plywood and Grizzly Grip thread” but I did that and it came out great. Thanks again for the idea. I still have GG left. Any other ideas on how to use it?
    EmilyW and Sjm9911 like this.
  18. Sjm9911
    5,312
    2,903
    Lol, nope . I'm only allowed one idea a year.....
    EmilyW likes this.
  19. Bultacobill
    Jan 14, 2020
    Ok so I still had a container left of GG. I used it to coat the underside of my mower deck. I thought it would hold up better than paint. GG is all gone now. I just need spring to get here to test out my work on everything.
  20. werkout52
    werkout52 New Member
    May 3, 2016
    I have a question about an alternate to GG. Will PVC roofing membrane work as an alternative? Got a roof brace for my 1998 Sea Pine and need to remove ABS since it is totally delaminated and has cracks all over. coleman roof.jpg
