Coleman ABS Roof
Discussion in 'Roof/Floor Repair & Maintenance' started by benfrench, Oct 11, 2011.
Have you had any issues with your Coleman ABS Roof?
  1. Yes, sagging, I fixed it ..
    15.7%
  2. Yes, sagging, I got rid of it ..
    4.0%
  3. No, never had any issues ..
    29.5%
  4. Yes, cracking, I fixed it ..
    52.0%
  5. Yes, cracking, I got rid of it ..
    10.9%
  1. Indyandy474
    Indyandy474 Member
    35
    32
    May 8, 2021
    Spencer Indiana
    It’s on the inside. From post to post, across front and back and 2 more running length wise on each side, trying to get you some pic’s
  2. Indyandy474
    Indyandy474 Member
    35
    32
    May 8, 2021
    Spencer Indiana
    I found a guy that posted the same repair I did, with unistrut.
    gi_jimbo and Sjm9911 like this.
  3. Indyandy474
    Indyandy474 Member
    35
    32
    May 8, 2021
    Spencer Indiana
    Sandra510 and Tom Z like this.
  4. Tom Z
    Tom Z Member
    61
    37
    May 8, 2021
    A back yard hack clapped on a roof top A/C unit dead smack center of roof near broke in half, had to sandwich bracing in and out and cover exterior bracing w fiberglass/boat resin to prevent water intrusion, took 3.5 days measuring cutting and welding and assembly ect.. So far so good.
  5. Tom Z
    Tom Z Member
    61
    37
    May 8, 2021
    Dude this is exactly what I was looking for when I went to do mine. Great job.
    Indyandy474 likes this.
  6. MApopupreno
    MApopupreno New Member
    Aug 16, 2020
    I thought I’d share my ABS sag fix, while simultaneously making a roof rack. I used superstrut u channel, 1/2” bolts to attach to the roof with very large fender washers on the inside. Total cost was about $200.
    Stardust1919 likes this.
  7. CoolCanuck
    CoolCanuck Member
    96
    47
    Oct 30, 2016
    Okanagan Valley, BC, Canada
    Miss Karla had a nice thread on the ABS Roof repair using the Struts back in Aug 2018.
    https://www.popupportal.com/threads/sagging-abs-roof-repair-with-photos-how-to-tips.120240/
    I had posted my version of the Unistrut / Superstrut repair there as well, starting with Post #6. These methods are pretty much in sync with the Youtube video reposted above...
    Mine is holding up well. Though I had left my trailer outside in the sun and preloaded the roof (somewhat) back into shape prior to attaching the strut.
    MApopupreno likes this.
  8. Indyandy474
    Indyandy474 Member
    35
    32
    May 8, 2021
    Spencer Indiana
    That looks great. Is it also a carrier for say a canoe?
  9. MApopupreno
    Aug 16, 2020
    That’s my plan. The weight distribution is great now, I weigh 215lbs and was almost fully on top of it for some of the install. Before this I was afraid to sneeze on it lol. From what I read, be sure to take the canoe off before raising the roof though.
  10. Indyandy474
    Indyandy474 Member
    35
    32
    May 8, 2021
    Spencer Indiana
    I did the same on the inside but I like your approach, it has more than one function.
  11. Indyandy474
    Indyandy474 Member
    35
    32
    May 8, 2021
    Spencer Indiana
    No
    regrets. Spent far too much wasted time chasing cracks and melting down white LEGO’s. It’s been 7 years and no problems at all. It’s the only way to go.
  12. Indyandy474
    Indyandy474 Member
    35
    32
    May 8, 2021
    Spencer Indiana
    My awning was attached with adhesive, attached to the abs. If the abs goes so does the awning. I have been wondering if any of us have re installed their awning after removing the abs?
  13. Sjm9911
    10,641
    8,024
    I haven't, i sold the pup. But if you wanted to, they sell metal track for the awnings, then drill holes through the foam and use a backer plate to distribute the weight. Bolt it though and seal it good.
  14. Indyandy474
    Indyandy474 Member
    35
    32
    May 8, 2021
    Spencer Indiana
    I thought the only way was to drill through but I really don’t want to do that. I’ll have to think about it. Right now I use a 12 x 12 canopy and it works well.
  15. Sjm9911
    10,641
    8,024
    I never used the awning on the pup. Wasn't worth the hassle after the bag ripped. But that was the plan before I sold it.
  16. Dano 445
    Dano 445 New Member
    Sep 28, 2019
    Wisconsin
    Hi Nolan,
    Where did you find the aluminum strip for mounting your awning?
  17. Fizbi
    Fizbi New Member
    Jun 4, 2016
    82604
    I peeled off the top ABS, left the foam on, and installed steel siding on my 12' Coleman.
    Pretty much water and hail proof.
    To do this I used three 14' lengths of steel siding from a big box store, stitched them together with stitching screws, then curled it over the top and bolted it down to the foam and inner ABS roof. I may trim it down a tad more but for now it looks super wicked. ;)
  18. Sjm9911
    10,641
    8,024
    Intresting and the first ive sceen done like that. Keep us updated on it!
  19. gi_jimbo
    gi_jimbo New Member
    Sep 4, 2021
    Western Nebraska
    I'm getting ready to do some repairs on the '96 Coleman my wife and I just bought. The ABS roof is actually in pretty good condition. One corner got smashed at some point and will need repaired. The rest only has a few minor cracks. The front and rear trim are actually in worse shape than the top. Before I order some MEK or acetone to make ABS slurry, I had a friend recommend the following stuff to me. Has anyone tried it? He swears by it but didn't know for sure how it bonded to ABS. He said it's bonded very well to other plastics for him.
    https://dicorproducts.com/product/self-leveling-ultra-sealant/
    Before fixing the cracks and GatorGripping it I was also going to do something similar to the unistrut support thing on the inside. It's only got a very slight sag in the center right now but thought I'd be proactive and get it supported now before doing everything else. While I may still go with Unistrut, I'm looking at building mine out of 80/20 instead. The extruded aluminum should be lighter than steel and provides good mounting options for hanging things like the door and new curtain racks to replace the old ones that will have to come out.
  20. Sjm9911
    10,641
    8,024
    Self leveling will seal it, and maybe prevent more water from going under the abs. Depending on how much water is under there depends on if the roof will delaminate or not. I would not gg it at this point.
