Thanks i have created a new thread, let me know if i need to do anything else, or a good person to reach out to.Yea, not abs. And rhats not good. Take a look at the thread I posted. And start a new one with the corect roof. Others will help. I have not had that roof.
Hi Nick,Hello all, new member here. Recently purchased a 1996 coleman santa fe will cracking/delaminating abs roof. I have gone through this whole thread and I am trying to confirm if anyone has had success with abs removal and then using the Henry's topicool silicone straight on the foam?
THANKS Nick
This is a common problem with the Coleman ABS roof system. The outer layer cracks and eventually de laminates. I purchased a 2001 Coleman Cheyenne and pretty much parked it for the winter and the following spring got ready to do some cleaning, repairing and what I thought would be touch up the roof cracks. However, the roof was so badly cracked that I soon realized I was looking at a much bigger repair. Then upon closer inspection I discovered that large sections of the abs plastic had completely separated from the layer underneath.I was wondering who here has a Coleman ABS Roof. Also, if you have had problems and fixed it, what did you do?
I bought it, the ABS peeled off while I was driving it home. I put Grizzly Grip on it. It is better than it was before.I was wondering who here has a Coleman ABS Roof. Also, if you have had problems and fixed it, what did you do?
I understand you completely stripped the plastic of the roof. But how did you work around the hold down buckles and awning rail (if you have that)? Did you leave the sides of the roof intact?This is a common problem with the Coleman ABS roof system. The outer layer cracks and eventually de laminates. I purchased a 2001 Coleman Cheyenne and pretty much parked it for the winter and the following spring got ready to do some cleaning, repairing and what I thought would be touch up the roof cracks. However, the roof was so badly cracked that I soon realized I was looking at a much bigger repair. Then upon closer inspection I discovered that large sections of the abs plastic had completely separated from the layer underneath.
I ended up completely stripping the plastic off of the roof. My solution was to paint on 3 coats of Flex Seal Rubber Paint. I rolled it on heavy and it took about 3 gallons. It is about $100 per gallon. That was done in the spring of 2019. We have traveled to Canada (3600 mile round trip), Kentucky twice (1600 round trip) Arkansas, Missouri and Oklahoma and been in lots of rain. Not a drop of water and the rubber is still like brand new after 3 full years. The only thing is it shows dirt and needs to go through a high pressure car wash a couple times a year to look nice and white.
There are other solutions and several good videos on Youtube regarding different solutions. I am not a real craftsman so using a spray gun, etc. was not in my skillset which is why I went with my solution.
This is off the Henry's topicool brochure I downloaded.. It mentions spray foam roofs as well.Hi Nick,
As you can see this is a really old, and very long thread. I have the same year and model of pup as you. I removed the cracked roof, just finished building the unistrut frame and installing inside to remove the sag. I am in the process of sourcing materials to seal the outside after going through and removing left over adhesive, and applying bondo to any places that foam got pulled away with the ABS. It was so delaminated that there are only a few spot that this is needed. I'll try to throw some pictures up later this week. Henry's sounded like a good choice for the outside, but I was leaning more toward Lanco Ultra Siliconizer, as it clearly states on the label that it can be applied to foam ( I assume that means spray foam, but the rigid foam of the roof doesn't seem much different).
I did not receive an awning with my camper. The awning rail was broken at both ends, so when I removed the abs I removed the rail as well. It was attached to the abs layer and not to the substructure of the roof so it came off easily. I use a 14 foot square canopy for the purpose of an awning/outdoor kitchen setup. Just make sure if you go this route you use a canopy that has vertical legs; some have legs that are angled and do not allow you to erect the canopy close enough to the camper to act as an awning. The 14 footer allows me to place the canopy across the entire length of my camper overlapping the roof and putting the drip edge over the roof. This is not always workable depending on tree location, type of parking pad, etc. You would also want to bring some sort of blocks that would allow you to level the canopy because of uneven terrain. If you are dead set on having an awning, you can purchase an aluminum replacement rail. It installs with a bunch of screws or bolts. But you have to drill into or through your roof to attach it. There is a polybutyl tape available at Camper's World which effectively seals out moisture and would be put between the rail and roof. It would effectively seal all points of water ingress I would think but I preferred my canopy solution.I understand you completely stripped the plastic of the roof. But how did you work around the hold down buckles and awning rail (if you have that)? Did you leave the sides of the roof intact?
Yes. Our Coleman Destiny had a roof that was sagging, cracking, and delaminated! We started out fixing it.I was wondering who here has a Coleman ABS Roof. Also, if you have had problems and fixed it, what did you do?
Thanks! I appreciate the detailed explanation. It's very helpful.I did not receive an awning with my camper. The awning rail was broken at both ends, so when I removed the abs I removed the rail as well. It was attached to the abs layer and not to the substructure of the roof so it came off easily. I use a 14 foot square canopy for the purpose of an awning/outdoor kitchen setup. Just make sure if you go this route you use a canopy that has vertical legs; some have legs that are angled and do not allow you to erect the canopy close enough to the camper to act as an awning. The 14 footer allows me to place the canopy across the entire length of my camper overlapping the roof and putting the drip edge over the roof. This is not always workable depending on tree location, type of parking pad, etc. You would also want to bring some sort of blocks that would allow you to level the canopy because of uneven terrain. If you are dead set on having an awning, you can purchase an aluminum replacement rail. It installs with a bunch of screws or bolts. But you have to drill into or through your roof to attach it. There is a polybutyl tape available at Camper's World which effectively seals out moisture and would be put between the rail and roof. It would effectively seal all points of water ingress I would think but I preferred my canopy solution.
As for the hold down buckles, I would use a reciprocating saw to cut around them leaving the rectangular abs pieces and buckles intact. On my unit none of these were delaminated at all. Then I just painted over the abs really well and so far it has held up. My camper is garaged when not in use. Being parked out in the elements 24/7/365 may impact the durability of my solution. I have been on some really long trips and driven 70-75 all the way. The rubber paint has adhered beautifully to the surface below with zero peeling, bubbling or loosening in any way (I also might mention that I did zero prep to the surface before I painted it). I have since seen that many people use bondo to smooth out the surface before applying their solution. I would have had a prettier finished product if I had done this but I didn't. I forgot to mention that I added a very fine silica sand to the final coat to add some texture. This was mostly for aesthetics.
I have used a high pressure car wash wand to wash it several times and have had no issues with peeling or separation so far. Just keep the nozzle at a reasonable distance to minimize this possibility.
For me Flex Seal was a cheap, easy and functional solution.
Have you tackled the roof coating yet? Any pics?Hi Nick,
I just posted an update with photos, in the “sagging ABS Roof Repair with photos & How to tips” thread if you want to see the progression.Have you tackled the roof coating yet? Any pics?
THANKS Nick
