Coleman Bayside Elite Roof Height Adjustment
Discussion in 'Lift Systems' started by Tiki-Dan, Aug 19, 2019.
  1. Tiki-Dan
    Tiki-Dan New Member
    25
    Jul 20, 2019
    Our Bayside Elite came with an ABS roof originally, but at some point in its past, the roof was replaced with an Alumitite roof. When the roof was replaced, I do not think the height was set properly as the upper door latches completely miss the catch, there fore the door isn't held securely.
    Ive checked under the door and the door seats down all the way. There is also extra canvas that bunches up, so that tells me the roof needs to be raised about an inch.
    The top is pretty much dead level when raised, so how do I go about adjusting all 4 lifts equally at the same time?
  2. McFlyfi
    McFlyfi Active Member
    439
    184
    Aug 1, 2014
    Thousand Oaks CA
  3. Tiki-Dan
    Tiki-Dan New Member
    25
    Jul 20, 2019
    Thanks so much! This is going to help me immensely.
  4. myride
    myride Well-Known Member
    881
    397
    May 14, 2015
    Edmonton, AB
    Pulleys first. ..all 4 corners...then check before you adjust at wiffle tree.
