Coleman Drawings?
Discussion in 'Miscellaneous Repairs & Maintenance' started by Shadow-D, Aug 27, 2019.
  1. Shadow-D
    Shadow-D New Member
    27
    22
    Jul 22, 2019
    Foothills of the Adirondacks, NY
    Maybe a strange question, maybe not but has anyone ever come across any original "blueprint" drawings for the Coleman tent trailers? I would be looking for the 2001 Grand Tours Mesa but I'm sure any of the early 2000's GT would work. I'm planning a frame off restoration on our Mesa and I'd like to have an accurate starting point. I'm sure I could do it the hard way if I had to... lol
    Thanks
    D
  2. Shadow-D
    Shadow-D New Member
    27
    22
    Jul 22, 2019
    2 year Bump
  3. Sjm9911
    10,749
    8,134
    Lol.
    ColoradoLizzy likes this.
  4. Tarkus
    Tarkus Member
    82
    60
    Aug 15, 2021
    Wyoming
    Blueprints?
    These matchboxes seem to be constructed by drunk sailors. In the process of repairing mine, I came to the conclusion that anything I did was 1000x better than the original design. My box is made up of a metal frame surrounded by the thinnest wood imaginable to hold up just long enough to make it out the showroom. Panels screwed into thin air, splintered wood, and impressive Styrofoam construction!
    In the process of repairing mine, I added extra wood where it made sense, added critical screws, framing, studs, and reinforcing brackets to keep the box from shaking apart. Mostly stapled together construction and hot glue! The staples had backed out and the hot glue tears off.
    Here's a photo before beefing up my rear section. This is with the ABS end-cap pulled off.
    This may be of help, probably not. https://colemanpopupparts.com/pages/model_specs
    Good luck!
    Shadow-D likes this.
  5. Lug_Nut
    Lug_Nut Active Member
    177
    136
    May 29, 2016
    Mt. Wachusett area, MA
    And that 'quality" construction would have driven up the build cost, thus pricing that higher than the competition's, would have increased the weight, so there's less capacity for YOUR stuff, would have increased the tow vehicle fuel consumption, accelerated tire and brake wear rates, every time the unit is moved. The build method that was used appears to have not been an issue for 23 years.
  6. Tarkus
    Tarkus Member
    82
    60
    Aug 15, 2021
    Wyoming
    LOL! ...and here we are trying to fix the issues.
    I wonder what the life span of these rigs was estimated to be 23 years ago?
  7. ChiefHart
    ChiefHart Member
    45
    18
    Apr 2, 2020
    Staunton, Virginia
    My 1993 Coleman Chesapeake, is in better condition now (2021) than just after I bought it. Rebuilt roof ends, new gaskets and bed gaskets, new better converter and breakers, new tires and wheels, electric brakes added, new mattress, roof painted, new AC/Heat Pump. In any case my popup is closing in on 30 years old and it is in great shape. So with proper maintenance they could last a half of century.
  8. theseus
    theseus Living the Darkside...
    3,398
    843
    Feb 6, 2007
    Centerville, OH
    There are wiring diagrams and repair books at colemanpopupprts.com that you can download. They are free.
    That’s as close as you will find for blueprints.
