Coleman/Fleetwood Outdoor Shower - Locked?!
Discussion in 'Miscellaneous Repairs & Maintenance' started by mottie, Sep 4, 2018.
  1. mottie
    mottie New Member
    Sep 4, 2018
    1998 Fleetwood (Coleman?) Sea Pine
    Hello! First time poster, new Tent Trailer owner.
    We just bought a (gently) used pop up and the outdoor shower compartment is locked. I've done some searching and gone through the manual but I couldn't figure out if it's a different key than the door or if our lock is jammed/stuck.
    Before I called a locksmith or tried to force it (and inevitably break the key) I figured I would ask here in case someone was familiar with this configuration.
    thanks!
  2. emoney
    emoney Well-Known Member
    880
    450
    Jul 7, 2018
    It's a standard key, called a "751" key. It's often different from a door key, but usually the same as your outside storage door, etc. Could've been changed from the PO. You can find them all over the internet, or your local dealer.
    It'll cost more from the local guy, more than likely, but it's quicker. Amazon will get you one in a couple days.
    WVhillbilly and mottie like this.
  3. mottie
    mottie New Member
    Sep 4, 2018
    Perfect, thanks for the quick reply. It was only $3.99 from Amazon and I'll have it in 2 days!
  4. mottie
    mottie New Member
    Sep 4, 2018
    Ugh - CH751 key just arrived and it doesn't work. Any other suggestions?!
  5. Halford
    Halford Well-Known Member
    3,563
    559
    Sep 28, 2011
    Santa Clarita, California
    It should not be different from other locks in the popup but true that PO may have changed the locks but it may be really stuck.
  6. rjniles
    rjniles Member
    899
    24
    Aug 7, 2009
    Georgetown SC
  7. Sjm9911
    4,532
    2,341
    Mine is the same as the main door key, that's for all compartments, patty etc for a 2000 Westlake.
  8. jnc
    3,921
    1,169
    Oct 1, 2014
    South Central New Hampshire
    It could also be Key #8025 which is the key to all the locks on both of my Colemans. You may want to spray some PB Blaster in the lock to free things up first.
  9. Raycfe
    15,247
    1,451
    The key numbers stated are the common ones along with a few others. If was at a campground I would ask my neighbors to try their keys. There is a good chance of finding one that works. That said .... drill it out and replace the latch .....very common ...... and do you really need to lock your shower? maybe just a latch that you could leave unlocked it you want. I did that on my Coleman with the front compartment also. It was a pain always needing the key to open.
  10. Sjm9911
    4,532
    2,341
    I was meaning to get to this, no need for the keyed locks on stuff like the potty! Or the front storage box, or the shower.
  11. mottie
    mottie New Member
    Sep 4, 2018
    First off the reason for needing the key - our shower was turned on full blast (when winterized last I assume) behind the locked door. Which made doing anything with city water basically impossible. If there's an indoor shutoff I couldn't find one.
    After lubing the lock I finally gave up trying to find keys or pick/bump the lock and used the key that fit best (front door key) and forced it as hard as I could with the knowledge that worst case the key would break and I've have to drill it out. The key bent but didn't break and the lock finally budged.
    It's now open, cleaned, lubed and working well. Turns out I didn't need a 751 after all!
    thanks for all your help/input.
    Orchid likes this.
  12. Orchid
    Orchid Sharp Shootin' Grandma
    5,333
    2,029
    May 8, 2011
    Florida by way of WV and MD
    I was going to suggest just keep trying all the keys you have. Ours all seem to work on all the locks sometimes, just have to keep trying and fiddling with them. We have 4 keys that randomly work on whatever locks they feel like working on that day.
    What really cracks me up is that there is a lock on toilet cabinet and outdoor shower, but not on the refrigerator or hot water tanks. Who would break into the toilet cabinet? [LOL][LOL]
  13. Halford
    3,563
    559
    Sep 28, 2011
    Willy Wonka might.
  14. WVhillbilly
    WVhillbilly Well-Known Member
    690
    474
    Jun 6, 2018
    WV
    Let he who has never run out of toilet paper cast the first stone.
    Orchid likes this.
  15. Orchid
    5,333
    2,029
    May 8, 2011
    There is no toilet paper in the outside part. [LOL] All you have access to is the black holding tank. While we only use ours for #1, DH is fond of saying "Sh*tter was full!" when emptying it, as people pass by.
    There is not much space in the exterior of the "sh*tter" cabinet, I suppose you could store your good drugs in there, but that's about it. [;)] It looks like the photo I'm attaching, except the fresh fill pipe is usually capped and folded in.
    When we first got our camper, the gold key fit this cabinet. Now one of the silver ones does. You just never know with these keys.
