coleman fleetwood roof repaired!!!
Discussion in 'Roof/Floor Repair & Maintenance' started by Ernie Hernandez, Jan 19, 2019.
  1. Ernie Hernandez
    Ernie Hernandez New Member
    Jan 8, 2018
    Like most of us coleman fleetwood pop up'rs my roof tore apart on the 101fwy it was cracking in the front corners and I put roof repair tape on it and thought this will do fine. cut to me picking pieces of roof off the 101fwy to save others form getting hurt.. made it home safe.
    Did my research and chose Grizzly Grip white they are very helpful and just mention you have a coleman fleetwood pop up and they know exactly what to offer you.. it was about $280ish for kits and come with everything but ask for a lrg roller and the two shorty rollers
    Here are some pics of the job done..First I pulled off all the entire molded ABS roof then sanded the hard foam mold that is under the white ABS roof, As you can see in the pics you want to crank up the roof up about 5 inches then cover the whole trailer with plastic sheet with Blue tape you do not want to get any grizzly grip on anything but the roof.
    I poured grizzly grip on the roof and before you use your textured roller I used a taping knife to spread the grizzly grip across a section, this stuff does not spread easily you have to go over and over and over again.Once you get the 2nd section done you have it down just be careful around the corners. Even if the rubber WEATHER STRIPPING comes off perfectly BUY a new one!!! ebay has plenty of them. Clean up is all up to you, I did two coats came out really good...
    IMG_4090.JPG IMG_4090.JPG IMG_4093.JPG IMG_4289.JPG IMG_4094.JPG IMG_4288.JPG IMG_4092.JPG IMG_4091.JPG IMG_4285.JPG IMG_4284.JPG
    jnc, J.SILVA, MrsSquid and 3 others like this.
  2. #iluvoutdoors
    #iluvoutdoors Member
    45
    Mar 7, 2017
    Looks great!
  3. Sjm9911
    4,686
    2,440
    Nicly done.
  4. nineoaks2004
    7,382
    3,142
    Dukes, Fl
    Looks really good, should hold up well.
  5. PopUpSteve
    PopUpSteve Administrator
    18,907
    1,650
    Dec 22, 2002
    Malvern, PA
    Looks great!
  6. Andy Close
    Andy Close New Member
    Feb 18, 2019
    Looks great! What did you do with the canopy? Or did it have one before?
  7. Ernie Hernandez
    Jan 8, 2018
    Never used it, so I took off the mold. I use a eazy up canopy.
  8. Martin G
    Martin G New Member
    Sep 18, 2017
    How much grizzly grip did you buy? What size was the popup roof?
  9. Ernie Hernandez
    Jan 8, 2018
    Two kits
    Coleman fleetwood
    Grandview SP
    Look up dimensions
    If your roof is smaller by 1ft or 2ft just get one kit
    If it’s the same size you will have to get two kits and you will have a lot extra and it has a 30 day expiration.
  10. Martin G
    Martin G New Member
    Sep 18, 2017
    My trailer is the same size - would 1 kit plus 4 extra bottles work?
  11. Ernie Hernandez
    Jan 8, 2018
    Yes for two coats that should work. But I don’t think they sell separates only the kits themselves If you want to do 3 coats which would be a positive overkill just get two kits it’s not expensive
  12. Tholihan
    Tholihan New Member
    Feb 17, 2019
    Looks great.
  13. CampingFamily1
    CampingFamily1 Active Member
    660
    113
    May 12, 2007
    Minneapolis/St. Paul, MN
    Nice to hear Grizzly Grip has become experienced helping Coleman roof owners fix the old roof problems!
    Well done and nicely displayed!
  14. andosfauxtos
    andosfauxtos Member
    43
    Aug 12, 2019
    Looks good! It's been about nine months now, how is it holding up? Also, when you reattached the four corner latches, did you just screw them directly into the foam, or did you use a backing plate on the other side?
