Coleman Lantern - my winter project this year
Discussion in 'Lighting, Interior and Exterior' started by thethird152, Dec 1, 2017.
  1. Lanternman
    Lanternman Active Member
    133
    165
    Aug 17, 2017
    Mooresville NC
    Awesome! Be careful, those things are addicting and multiply if you place them too close to each other LOL
    I really need to book that rally next year! Octobers are tough for me, the rally weekend is the only weekend Ill be home for the next 5. If I attend, ill be living in it HAHA.
    Hmmm, wonder if I could sneak a ride in just to visit though........
  2. thethird152
    thethird152 Active Member
    621
    110
    Feb 1, 2015
    Mt Pleasant, MI
    You wouldn't regret it - it's looking to be the largest turnout yet. Great folks, great food, great times.
    Lanternman likes this.
  3. Lanternman
    133
    165
    Aug 17, 2017
    Mooresville NC
    Can I bring beer? :laugh::laugh::laugh:
  4. Sjm9911
    6,877
    4,236
    Fun read! You might get me restoring some stuff.
  5. Lanternman
    133
    165
    Aug 17, 2017
    Mooresville NC
    Be warned- it may be worse than crack. LOL
  6. thethird152
    621
    110
    Feb 1, 2015
    Mt Pleasant, MI
    You certainly can, but if you don't there is plenty of extra in everyone else's coolers!
  7. Katskamper
    Katskamper Active Member
    778
    224
    Nov 21, 2015
    Fort Worth, TX
    so, this is what i bought this morning at neighbors garage sale.
    this lantern does NOT sit in the case correctly.
    needs glass & mantles first.
    is the case from 1980?
    lantern bottom is stamped 11-92.
    or are those part/model numbers?
    ten dollars! D4FD571F-D2F3-47B5-A9C3-F1CDBD1C0482.jpeg 8D956568-6982-4ACB-B666-E973D34B5242.jpeg 53B64FBC-94E6-43B1-8533-FCC3537D2299.jpeg 77A0D379-DCA0-42F8-A2A2-4A5EAA1F0674.jpeg
    Orchid likes this.
  8. Katskamper
    778
    224
    Nov 21, 2015
    Fort Worth, TX
    ok i know what the white camp fuel is, but what is the “other” fuel?
    what is the fuel difference between the white camp fuel & kerosene?
    i have a can of each, Kerosene specificly for an oooooold black kerosene heater, which i have not used since i acquired it.
  9. xxxapache
    3,259
    1,234
    That lantern will run on Coleman fuel or unleaded gasoline.
    Coleman did make and I believe still makes a kerosene lantern. I have one. To light it, you have to preheat the generator with alcohol before you start the kerosene flow....It is a very neat lantern to run.
    Katskamper likes this.
  10. Bowman3d
    Bowman3d Well-Known Member
    863
    372
    Apr 13, 2015
    LaLa land (SoCal)
    Is that a Sears single mantle i see in the front? I've been looking for one of those for awhile
  11. Katskamper
    778
    224
    Nov 21, 2015
    Fort Worth, TX
    the lantern sure looks new/ used once.
    i added new fuel, new mantles.
    pumped it up firm.
    turn on to light- NOTHING.
    took apart, yes fuel squirts out brass stem.
    reassembled
    will not light
    suggestions?
  12. xxxapache
    3,259
    1,234
    Are you saying fuel squirts out at mantles and won't light?....if so, sounds like bad fuel or the wrong kinds fuel.
  13. Katskamper
    778
    224
    Nov 21, 2015
    Fort Worth, TX
    no, when i took it apart, took th top part w mantles off, fuel squirted, like thru a syringe.
    never head rhe hiss of gas that i expected... should there be?
    fairly new can fuel.
  14. Bowman3d
    863
    372
    Apr 13, 2015
    LaLa land (SoCal)
    When you checked if fuel was getting through did you check it with the generator on or just the valve? Make sure gen is not clogged and also the air tube ( the part that the generator sticks into) is not plugged ( favorite place for mud wasp nest)
  15. xxxapache
    3,259
    1,234
    I agree....check for dirty generator.
  16. Katskamper
    778
    224
    Nov 21, 2015
    Fort Worth, TX
    This is my first liquid fuel lantern w mantles. (my other lights are all propane can type or old railroad oil lamps.)
    so i dont have a book or know the lantern part names.
    but i found it on google!
    its bright daylight, so maybe i can see something.
    will get a new bottle of gas at wally later.
    in the meantime, work on the old stove i got this summer to refurb.
    scraping out old crusty gasket an gas cap, etc.
  17. Katskamper
    778
    224
    Nov 21, 2015
    Fort Worth, TX
    ez off oven cleaner melted the paint off!
    was not expecting that!
    i replaced the leather cup in pump with original leather.
    the fuel i used in lantern worked in stove& i now have nice blue flames on both burners!
    aux valve needed some coaxing w pliers to open.
    first time that stove has been lit in 20 years! whoo hoo!
  18. xxxapache
    3,259
    1,234
    Yes, I put oven cleaner on a 3 burner last year and discovered it takes the Coleman paint off....I ended up stripping that stove and painting it to match my TT.
  19. Katskamper
    778
    224
    Nov 21, 2015
    Fort Worth, TX
    back to the lantern.
    dumped the gas out, & filled 1/2 way with Coleman gas. the pump is the newer plastic parts, so i used the old leather cup & added to assembly to help it, & pumped it up.
    took off tip of nozzle on generator & clean, reassembled lantern.
    i do not hear the hiss of gas.
    did not light.
    new mantles from last night now dust.
    is it saveable.?
  20. xxxapache
    3,259
    1,234
    Yes, it is saveable....Hard to diagnose without it in front of me, though.
