Coleman Niagara Lift Switch
Discussion in 'Lift Systems' started by chrispt, Aug 17, 2019.
  1. chrispt
    chrispt Member
    43
    Mar 27, 2019
    Midlothian, VA
    So, we managed to short out the switch on our Niagara for the lift system. Does anyone know if that can be replaced individually or do I have to buy other parts?
    Also, since we are at a campground right now how do I unplug the motor as it says to do so I can raise and lower the pop up manually?
  2. GreyFox
    GreyFox Well-Known Member
    1,569
    772
    Oct 10, 2018
    S Ontario
    Go to these repair guides, scroll down to Lift Systems, and click on the guide for your particular lift system. On Page 7 are instructions on how to manually operate your electric lift system.
    https://colemanpopupparts.com/pages/repair-guides
    As I recall your electric lift system was manufactured by Barker Mfg so you might also give them a call for further information.
    https://www.barkermfg.com/contact.html
  3. Dingit
    Dingit Well-Known Member
    900
    424
    Mar 8, 2017
  4. chrispt
    chrispt Member
    43
    Mar 27, 2019
    Midlothian, VA
    This is very helpful. I do have a 2007! I see a white connector between those cables but no black. The color of the wires is the same. Glad to see I can't damage it either way.
  5. BikeNFish
    BikeNFish Well-Known Member
    3,019
    1,921
    Apr 24, 2017
    Maplewood, MN
    When my switch crapped out on me on my Flagstaff, I took it out, found the part number (HY29D) on its side and ordered a new one from Grainger for less than $10.
  6. Dingit
    900
    424
    Mar 8, 2017
    Hope it worked. I've never tried it!
