Coleman PVC Front Trim Wear Plate under Bed
Discussion in 'Camper Restoration Projects' started by CoolCanuck, Aug 28, 2019.
  1. CoolCanuck
    CoolCanuck Member
    64
    24
    Oct 30, 2016
    Okanagan Valley, BC, Canada
    I've got a 1997 SunRidge, where I have to rebuild the cargo lid surround / aka Trunk Cap. About 70% of the PVC plastic wear plate at the front is missing ...
    It's shaped like an "L", 3/4" x 1 1/2" and is attached on top of the top cargo box surround / cover. The rubber strip attached to the bed covers the trim. Strangely, I have what appears to be an aluminum plate in the rear...
    Anyone know where to get the plastic trim piece or can one replace it with a flat aluminum plate?
    thx
  2. CoolCanuck
    CoolCanuck Member
    64
    24
    Oct 30, 2016
    Here's the pics:
  3. Pozi
    Pozi Member
    97
    26
    Feb 17, 2016
    I think an aluminum replacement piece is a good solution. I bet if you walked up and down the aisles of your local home improvement store you'll find something that'll work well.
  4. CoolCanuck
    CoolCanuck Member
    64
    24
    Oct 30, 2016
    I'm in Canada... selection here is, well, close to that in Russia... ;)
    Anyone know what the aluminum ones from Coleman/Fleetwood looked like in later years? Size, if known?
  5. jon davenport
    jon davenport New Member
    17
    Aug 22, 2019
    Kansas
    its basically a drip cap. Local hardware store has aluminum flashing2-3 in. If you happen to know anyone who installs siding and has a " break" they could bend it for you more than likely for free. or just clamp a couple of boards together and bend it over. Just a few ideas from me. Best of luck
  6. myride
    myride Well-Known Member
    867
    388
    May 14, 2015
    Edmonton, AB
    Lowe's has aluminum L in various lengths and widths....so does rona if you still have one.
  7. CoolCanuck
    CoolCanuck Member
    64
    24
    Oct 30, 2016
    Thanks... will continue to look.
