Coleman stove mounting bar
Discussion in 'Deals too good not to share!' started by tzmartin, Jan 7, 2020.
  1. tzmartin
    tzmartin Well-Known Member
    941
    365
    Sep 9, 2015
    just bought this Coleman Fleetwood style outdoor stove mounting bar. Don't know exactly what the proper name of it is but it was $16.92 for about a 32 inch long bar. It's $20 for only one side of it on eBay. I'm going to make a shelf for the side of my camper where the stove goes.
    https://www.amazon.com/gp/product/B00MJVEESW/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    I'll attach these cool little 90 degrees supports to hold the shelf up
    https://www.amazon.com/gp/product/B07FKFLJJD/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
    megcabra, ezakoske and Sjm9911 like this.
  2. ezakoske
    ezakoske Active Member
    525
    75
    Nov 30, 2014
    Escondido, CA
    I like those 90 degree brackets! Are you planning to put the shelf next to the stove? Are you going to put the long leg or the short leg against the side of your PUP?
  3. tzmartin
    941
    365
    Sep 9, 2015
    Good questions. I'm going to have one table instead of the stove. I don't use the stove too much, but will have it around when needed. I'm undecided about the long leg or short leg against the side. I believe it's easier to retract when the short side is against the side. There's a button on the long arm that releases the angle arm easily. I might attach a sightly longer piece of wood on the short arm to distribute the weight better. I'll play around with it and see.
