Coleman Tacoma out of alignment?
Discussion in 'Lift Systems' started by Jimbow, Apr 14, 2013.
  1. Jimbow
    Jimbow Active Member
    1,345
    Nov 30, 2012
    I was looking at my roof after I cranked it down and notice one corner jams into the pup.
    The opposite diagonal seems over too far out. Is this adjustable? Signs of a mishap?
    Sent from my iPad using Tapatalk HD
  2. Bjess
    Bjess Quiet Time
    61
    Aug 22, 2010
    Did you put lid down with the stabilizers down? I have heard that what you have could be caused by that. I could not tell you how to adjust it. I am sure someone will though! Love the Portal!
  3. Jimbow
    1,345
    Nov 30, 2012
    Nope stabs up on a fairly level site.
  4. phalynx
    phalynx Member
    284
    Aug 27, 2011
    Are the latches all adjusted to the same length?
  5. Jimbow
    1,345
    Nov 30, 2012
    I will check that. The issue I see is the roof sits away an inch or so on the front side and like the picture on the opposite corner.
  6. phalynx
    phalynx Member
    284
    Aug 27, 2011
    Sorry, I missed the part where you said the roof is misaligned side to side and I was thinking the latches just weren't pulling the roof down evenly.
    Something's not right, but I'm of no help here. Good luck.
