Colman folding oven
Discussion in 'Boondocking' started by gladecreekwy, Jul 27, 2019.
  1. Bowman3d
    Bowman3d Well-Known Member
    972
    505
    Apr 13, 2015
    LaLa land (SoCal)
    That's the one Im looking for to go with my 426b in the pic above you YCG. But I can't seem to find one in good shape that they don't want a lot of money for. After I get one of those I’ll look for this
    SHFL and neighbormike like this.
  2. dbhost
    dbhost Well-Known Member
    1,264
    721
    Sep 19, 2018
    League City, Texas USA.
    Is that real or is that photoshop?
  3. Bowman3d
    972
    505
    Apr 13, 2015
    LaLa land (SoCal)
    It’s real. Extremely hard to find. C
    it’s real. But try and find one. It’s what you call unobtainium
    Product Discontinued by Manufacturer
    Coleman Rugged Collapsible 2 Burner Camp Oven has been discontinued by Coleman and is no longer available. Our product experts have helped us select these available replacements below. You can also explore other items in the Outdoor Gear, Camping Gear, Camping Stoves categories yourself to try and find the perfect replacement for you!
    J Starsky likes this.
  4. gladecreekwy
    1,533
    2,356
    Sep 25, 2016
    Jackson Wyoming
    We buy par baked crusts and bring the toppings.
    Sjm9911 and YellowCityGuy like this.
  5. Tulip
    Tulip Active Member
    156
    161
    Jul 25, 2018
    Do these only work on Coleman stoves or can you use them with the propane stoves that come with the trailer?
  6. Be-Ce
    Be-Ce Active Member
    100
    33
    Apr 5, 2017
    Albany, Oregon
    @Tulip There is a round ring on the bottom of the oven that needs to be centered on the burner. Our three burner stove wouldn't allow this, geometrically. Hence, the use of a single burner that we use.
    Tulip likes this.
  7. gladecreekwy
    1,533
    2,356
    Sep 25, 2016
    Jackson Wyoming
    I have used on on the our stove that hangs off the side of the camper. Worked ok but I wasn’t watching it close enough and it started to melt the plastic stove housing. Probably why I stoped using it years ago. Required a two burner Colman. It’s really designed for steel campstove. Lots of heat trapped under and redirected down. I would never use inside
  8. kitphantom
    13,221
    2,333
    I would not use the Coleman oven on the inside stove. It's really designed to sit on the Coleman camp stoves. If nothing else, having a good space around it for air circulation is necessary. I would also not use the Outback Oven we used for a very long time on the inside stove. I would worry about the reflected heat from the cover causing damage to the cook top, if nothing else; the Coleman oven could do the same due to clearance between the bottom of the oven and the cook top.
    One reason we bought the Omnia oven is so we could use it on the inside stove if we want, it is designed so it can be used on boat and RV stoves. Last week, we used it outside on the camp stove, because it was in the 80s and we didn't want that extra heat inside the camper.
  9. dbhost
    1,264
    721
    Sep 19, 2018
    I could totally go for one of those with a proper baking stone to insure even heat over a white gas stove...
  10. lksdrinker
    lksdrinker Active Member
    210
    54
    Oct 15, 2018
    I'm glad I came across this thread. I've seen these in photos but didnt realize that a) they fold down flat or b) that they worked well! Now I think I might need to find one....especially since we decided to try camping on Thanksgiving this year!
    An old three burner just like mine. Love it! No problem using the oven on this (someone else commented they couldn't use this on their 3 burner for some reason). Now tell me about those side tables! Were they custom made or something offered by coleman?
  11. gladecreekwy
    1,533
    2,356
    Sep 25, 2016
    Jackson Wyoming
    Lots of older ones on eBay
  12. dbhost
    1,264
    721
    Sep 19, 2018
    You wouldn't happen to be on the Coleman Collectors Forum would you? There is a lot of Thanksgiving camping talk there. Kind of my fault...
    The side tables were a Coleman thing, I see them on Ebay periodically.
    The single best ting I did for my coleman folding oven was to add the baking stone to it. Makes the heat a LOT more even in there...
    FWIW, to use the Coleman Oven on a Coleman 424 or 425, I typically use the right burner, with the windscreen folded in and the oven centered over the burner head. I found that if I try to keep the bottom of the oven over the stove entirely, the right side of the oven gets too hot the left not hot enough.
  13. lksdrinker
    210
    54
    Oct 15, 2018
    I see that. Not sure I necessarily need an older one. cool nonetheless.
    I believe I am registered on that site....but admit I don't frequent it at all. We are all set for thanksgiving camping but were a bit worried about things that need to be baked rather than simply cooked.
    I'll have to keep an eye out for those side tables!
    So when using that right burner, you have 'half' the oven overhanging the side of the stove? I imagine if I try to center it over the middle burner it leaves the other 2 burners unusable?
  14. dbhost
    1,264
    721
    Sep 19, 2018
    I will start a Thankgsiving dinner in camp thread here to give a rundown of my thought process and equipment used...
    https://www.popupportal.com/threads/anyone-camp-for-thanksgiving.126602/
  15. Bowman3d
    972
    505
    Apr 13, 2015
    LaLa land (SoCal)
    The problem with using the oven on a tree burner is the main burner is in the middle when you center the oven over the main burner there is not much room for using the auxiliary burners on the sides. The spread between burners on a 426 is the same as a 425. In theory The ideal stove to use is a 413. They have more room between burners.
    The trays on the side are called Chef trays. They are not made to be used on a 426b ( I custom made mine to fit my stove) . The trays are made for 426d and 413 g and after. But if you don’t mind cutting and drilling your case you can get them to fit. Mine are made from steel real ones are aluminum much lighter.
  16. lksdrinker
    210
    54
    Oct 15, 2018
    Gotcha. Thanks!
  17. dbhost
    1,264
    721
    Sep 19, 2018
    For what it's worth, I have used mine on the 425F, which is effectively the same stove as the 424 with a smooth case and a CF only generator instead of the larger dual fuel... The problem is that it is physically impossible to center the oven over the primary burner due to the way the hinge is in the way of sliding the oven to the right. This means that the right side of the oven tends to operate hotter than the left, resuliting in burnt food on the right side of the oven while the left is perfectly done.
    I did this to test using the oven without my mods.
    Now the mods i have tested, and need to retest (NOT on the plastic table!) is using a baking stone on the bottom of the oven to even out the heat. Another option would be to remove the lid / wind screens so that the hinge is not in the way...
  18. dbhost
    1,264
    721
    Sep 19, 2018
    Just FYI, for build your own pizza night, depending on your dietary needs, French Bread split and cut to length makes a good crust if you can do the high carb approach.
    For low carb, Carb smart flour tortillas make a great base.
    My wife and I do carb smart tortillas, Jarred marinara sauce, minced veggies, typically red onion, bell pepper, thin sliced tomatoes, spinach, mushrooms etc... and of course pre prepared meats, and shredded mozerella. Sprinkle on a touch of Italian seasoning and garlic powder and bake at 350 deg for 25-30 minutes while you mix the Cesar Salad kit, and dinner is done.
    gladecreekwy likes this.
  19. AndreD
    AndreD Active Member
    102
    47
    Jul 24, 2020
    Great White North
    I have one as well, firebricks in bottom and it works fine. Not as great as your home oven obviously but with adjusted expectations it works just fine.
    dbhost and gladecreekwy like this.
  20. gladecreekwy
    1,533
    2,356
    Sep 25, 2016
    Jackson Wyoming
    Love when an old thread makes a comeback. Just packed mine into my camper. Ready for summer
