Anubisuna
New Member
Nov 18, 2022
Indianapolis, Indiana
Camper- 1990 StarCraft Meteorite
Tow Vehicle- 1999 Jeep Wrangler TJ Sport
So I purchased this Meteorite about a year ago, in hopes of renovating it (kind of) and getting it out in the wilds a bit, but I knew it would take some time to get around to doing it. Life is giving me some leeway so I'm getting started on prep for this thing. My main concern is finding out all the information I can currently about the model and options, and where to find some parts, before I start self fabrication. The title states that it's a 1990 Star Craft Meteor. The Show's the text "Meteorite" next to the door however.
The layout doesn't seem to match anything properly for year/model that I've found.
The problem is this. In Picture (A) You can see the layout of my pop up, exactly matched, except theres a few differences in the stovetop, but the 1990 model (Picture B) there is no Meteorite (the layout is not the same as the meteor but the title states Meteor) The side of the camper says meteorite and the layout is the same as starflyer/spacestar but the beds are the same size.
I'm so confused because the title says Meteor, the camper says meteorite and the layouts are all wrong, for the years. I can upload pictures of the camper shortly, and I'm going to double check for matching VIN but I want to make sure I'm on the right path before I start work on this thing.
Thanks in advance for any help!
Lug_Nut
390
Mt. Wachusett area, MA
Meteor and Meteorite were two different layouts. I had a 91 Meteorite. The side dinette / bed was opposite the entry door with the sink and stove near the rear pull-out. The Meteor had a full width table / bed at the rear pull-out with the sink and stove near the front bed.
Anubisuna
New Member
Nov 18, 2022
Yep that sounds like what I have, I’ve been trying to find some parts and stuff for it before I fab them but things don’t seem to be lining up and the title says differently but it all matches up. I’m moving it to my shop tomorrow to get ready to hit it and renovate it, I wanted to replace the factory door though, and add heat/air and batteries. I just like having all the right factory Info just in case.
