converter problems
Discussion in 'Wiring' started by jeeper88, Oct 6, 2019.
  1. jeeper88
    jeeper88 Let's go Camping and Jeepin
    762
    17
    Apr 24, 2011
    Ocala,FL
    WFCO Arterra WF-8725-PB Power Converter
    Here is what I have. My neighbor told me to plug into his 30 amp so I did. Well it was a 220 30 amp. My 12 volt side still works not 110 side. I found the internal fuse and it is blown. Not sure if it is soldered in or a pull out fuse and I cant tell what size it is. Can anyone help me with with the size and if I can just pull it out?
  2. PopUpSteve
    PopUpSteve Administrator
    18,800
    1,568
    Dec 22, 2002
    Malvern, PA
  3. MNTCamper
    MNTCamper Active Member
    855
    174
    Jun 14, 2014
    MN
    Remove the cover and pull the fuse. It is a standard household fuse just like you have in your box at home, they snap in and out. Might be tripped or blow. You should be able to see it just opening the cover of the unit, but to remove the fuse, you have to take the cover and plate off.
  4. jeeper88
    762
    17
    Apr 24, 2011
    Ocala,FL
    upload_2019-10-8_12-10-14.jpeg here is the blown fuse upload_2019-10-8_12-10-14.jpeg
  5. jeeper88
    762
    17
    Apr 24, 2011
    Ocala,FL
    Sorry at least u can see it
  6. jeeper88
    762
    17
    Apr 24, 2011
    Ocala,FL
    as you can see i cant see what size the fuse is. I could guess and say 5 amp 125 volt. also its soldered in not like a household fuse.
  7. GreyFox
    GreyFox Well-Known Member
    1,301
    588
    Oct 10, 2018
    S Ontario
    Why would you not contact WFCO and ask what rating this fuse should be?
    https://wfcoelectronics.com/support/
  8. jeeper88
    762
    17
    Apr 24, 2011
    Ocala,FL
    hmm Didnt cross my mind.. I did find out tho. Is an 8amp 250 volt
  9. NMroamer
    NMroamer Active Member
    503
    249
    Apr 21, 2016
    Albuquerque NM
    No need to the amp rating and voltage is stamped on the end of fuses like that.
  10. tombiasi
    5,241
    915
    That's not a blown fuse. It's a physically damaged fuse. How did it get like that?
  11. Fless
    Fless Active Member
    940
    191
    Aug 14, 2012
    Colorado
    Your 12v probably works because it may be being fed by your battery.
    _
  12. jeeper88
    762
    17
    Apr 24, 2011
    Ocala,FL
    Yes 12 volt worked fine. The fuse broke when I tried to remove it not knowing it was soldered in. I had enough of the pins on the side of the fuse I could solder a fuse holder on, so now I I can replace with a new fuse without dealing with the PC board. Its what they should have done in the first place.
  13. jeeper88
    762
    17
    Apr 24, 2011
    Ocala,FL
  14. jeeper88
    762
    17
    Apr 24, 2011
    Ocala,FL
    Here is what I did. It was an 8 amp so I used a 10 amp. Anyone see any problems with this? I turned all the ac stuff on even the HI speed on the ac , refridge, water pump all my lights and had 3 of the outlets being used. all went well for the 3 hrs i had it fired up and no prob. so am I wrong to fix it the way I did?
  15. GreyFox
    1,301
    588
    Oct 10, 2018
    S Ontario
    It would seem you're confused as your converter has nothing to do with the trailer's 120 vac system, other than being a convenient location to mount the 120 vac breakers and 12 vdc fuses. Incoming 120 vac shore power is fed to the input side of the converter and to breaker(s) that feed the trailer's 120 vac receptacles. This 120 vac does not go through the converter except to feed it so it can convert that 120 vac to 12 vdc so to say you had some 120 vac devices running (A/C for example) is irrelevant to your issue. If the original fuse had an 8 amp rating then that's what you should replace it with.
  16. jckele
    jckele Member
    148
    May 24, 2011
    Just curious, how could you possibly plug a 30a/120v rv plug into a 220v outlet of any current rating?
    Something there needs to be addressed before a real accident occurs!
  17. jckele
    jckele Member
    148
    May 24, 2011
    From your picture it also appears that you may have soldered a automotive fuse holder in place of the original? I seriously doubt that the automotive fuse is rated for any more than 32v. That fuse soldered on the board will be for the primary, 120v side of the converter. It is not user replaceable cause normally when it blows it indicates an issue that a user can not repair. The 12v side will have a replaceable fuse to allow the user to change.
    You can buy fuses with leads attached or you could use a rated fuse and holder soldered in as you already did.
    "The voltage rating of a fuse is a function of its capability to open a circuit under an overcurrent condition. Specifically, the voltage rating determines the ability of the fuse to suppress the internal arcing that occurs after a fuse link melts and an arc is produced. If a fuse is used with a voltage rating lower than the circuit voltage, arc suppression will be impaired and, under some overcurrent conditions, the fuse may not clear the overcurrent safely"
    Just my opinion
  18. tombiasi
    5,241
    915
    If the broken fuse was on the AC side to feed the converter you have an automotive fuse in there rated for 15-35 volts.
    EDIT: Sorry jckele your post wasn't there when I posted. Probably should have refreshed the page.
  19. jckele
    jckele Member
    148
    May 24, 2011
    It sure is!
    I'm still wondering how one plugs a 120v trailer into a 240v outlet as the OP stated, and no one else questions it!
  20. tombiasi
    5,241
    915
    I just figured he thought it was 220v, many people on here have assumed the 30 amp outlet was 220v.
