Converter switch reference in 1640LTD manual
Discussion in 'First Time & New Camper Owners' started by Bruce Hull, Jul 9, 2019.
  1. Bruce Hull
    Bruce Hull New Member
    Jul 8, 2019
    This will probably apply to Rockwood Freedom owners. Don't know if anyone has encountered this or just has 2 cents to add, but I put our 2010 Rockwood 1640LTD on shore power and according to the manual, was supposed to make sure the 3-way switch was in the appropriate position. Spent 30 minutes looking for said switch, but couldn't find it. Outlets and fridge worked, so I assumed it was an older set of instructions and the "switch" was now automatic. Also, could someone verify that the battery is being charged when on shore power. Thank you. I apologize if this should be in another forum.
  2. Sjm9911
    3,934
    1,954
    My 3 way switch is on the back of the fridge, outside the pup. Look for an acess hatch. Thats on an older Coleman.
  3. Bruce Hull
    Jul 8, 2019
    That's what I initially thought, but the instructions reference a button being pushed in and specifically on the converter. I'll look at the converter model, but it seems to work without my doing anything.
  4. joet
    4,409
    810
    To verify that your battery is being charged, you need a volt meter to check volts at the battery
    Bruce Hull likes this.
  5. Snow
    9,914
    893
    Older trailers had to have the converter manually switched from to shore power to battery and back depending on which power source you were using..
  6. rabird
    6,582
    258
    TX
    Bruce Hull, you need a up to date manual. ~97 or so they stopped using the switch you mention (conv-off-batt).
    A 2010 model should provide some charge to the battery if working correctly.
    Bruce Hull and Raycfe like this.
  7. Bruce Hull
    Jul 8, 2019
    I downloaded an updated manual and it did mention testing the voltage at the battery cables with the battery disconnected and on shore power. Thanks for the responses.
